Offline apt-get
Offline apt-get
Postby tuxmando » Thu Dec 06, 2007 10:26 am
Hi, I don't currently have a net connection to by ubuntu box, but i have fast connection at college. Is there a tool i can use on the box and under windows for grabbing dependencies? What I'm after is, say, installing anjuta requires thispackage.deb and writes it to a list, same list can be run in windows program to fetch the file and any others that the next one depends on.
tuxmando
RE: Offline apt-get
Postby pootman » Thu Dec 06, 2007 10:37 am
Doesn't Synaptic have an option in the file menu to create a download script?
pootman
RE: Offline apt-get
Postby Dutch_Master » Thu Dec 06, 2007 10:40 am
Goto http://www.debian.org/distrib/packages#search_packages then select whatever package you want to know the dependencies of and get them from there.
RE: Offline apt-get
Postby tuxmando » Thu Dec 06, 2007 10:54 am
Thanks for the quick replies.
pootman, i'll check that at home.
dutch_master, that page will let me do it one file at a time but what i'm after is more complicated, don't think i explained properly.
What i want is this:
On ubuntu I create a list of installed debs and their versions and store this on my usb key.
I decide to install mypackage.deb and all dependencies, with all their dependencies, and so on. I've used the dependency finder but i have to download a package at a time, go home try to install again and get another package needed. or, i have to click through following all the dependencies on the download site which gets me lost and takes ages. What i'm kind of after is a version of apt for windows which won't install the packages but will download them ready for my ubuntu box to install.
tuxmando
RE: Offline apt-get
Postby nelz » Thu Dec 06, 2007 12:02 pm
You could use APTonCD.
RE: Offline apt-get
Postby tuxmando » Thu Dec 06, 2007 12:13 pm
Thanks, that looks great for when I have the packages and I'll use it for reinstalls, but i'm after an easier way of getting them in the first place. thinking i might make something myself
tuxmando
RE: Offline apt-get
Postby nelz » Thu Dec 06, 2007 2:26 pm
What if you run "apt-get --download --simulate pkgname"? I'm not near a Debian system now, but that should show you which packages it wants to download.
RE: Offline apt-get
Postby tuxmando » Fri Dec 07, 2007 10:09 am
thanks for trying but i'm not sure i can do what i'm after. i can do what your suggesting but it means doing it for every extra that has dependencies. what i could do with is an ubuntu install running on the college comp in a virtual machine but we're not allowed them. i had thought of knocking up a sort of pseudo synaptic for windows which would download the file i want, check the control file for deps then download them as needed, but i think it's beyond my abilities at the moment. do you know where best i could look for the method of checking the control file then downloading debs? i'd probably do it in c# because that's what we're learning but i've done some c++ before. is there a resource you'd recommend or is it a google job?
tuxmando
RE: Offline apt-get
Postby tuxmando » Fri Dec 07, 2007 10:11 am
that looks kind of crazy, looking at it! what i mean is how do i find out the steps from querying a site for a giving dependencies to downloading it from the site?
tuxmando
RE: Offline apt-get
Postby nelz » Fri Dec 07, 2007 1:22 pm
It seems you didn't look closely enough. apt-get will automatically install dependencies, and the --print-uris option will output the URIs of all the files it needs. You can use grep and cut to extract the URIs fro the output with
apt-get --print-uris --yes install pkgspec | grep ^\' | cut -d\' -f2
For example, running this with "postgrey" as the pkgspec gives this output
http://security.ubuntu.com/ubuntu/pool/universe/libn/libnet-dns-perl/libnet-dns-perl_0.59-1build1.1_i386.deb
http://gb.archive.ubuntu.com/ubuntu/pool/universe/libb/libberkeleydb-perl/libberkeleydb-perl_0.31-1_i386.deb
http://gb.archive.ubuntu.com/ubuntu/pool/main/libd/libdigest-sha1-perl/libdigest-sha1-perl_2.11-1build1_i386.deb
http://gb.archive.ubuntu.com/ubuntu/pool/main/libd/libdigest-hmac-perl-dfsg/libdigest-hmac-perl_1.01-5_all.deb
http://gb.archive.ubuntu.com/ubuntu/pool/universe/libi/libio-multiplex-perl/libio-multiplex-perl_1.08-3_all.deb
http://gb.archive.ubuntu.com/ubuntu/pool/universe/libn/libnet-cidr-perl/libnet-cidr-perl_0.11-1_all.deb
http://gb.archive.ubuntu.com/ubuntu/pool/universe/libn/libnet-ip-perl/libnet-ip-perl_1.25-2_all.deb
http://gb.archive.ubuntu.com/ubuntu/pool/universe/libn/libnet-server-perl/libnet-server-perl_0.94-1_all.deb
http://gb.archive.ubuntu.com/ubuntu/pool/universe/p/postgrey/postgrey_1.27-4_all.deb
All the debs needed to install postgrey and its dependencies.
You can give more than one package name as pkgspec. However, you do need to run the apt-get update from time to time to keep up to date. If you are using another connection because your home computer is on a slow dialup, there is no problem as apt-get update doesn't download much. If you have no Internet access at all, you can run
apt-get --print-uris update
and download the files elsewhere. Then copy, unpack and rename the Sources files in /var/lib/apt/lists.
When using apt-get --print-uris, redirect the output to a file and copy this to a USB flash drive to take it to the Internet connected computer. Some FTP programs will read the URLs to download from a file, such as
wget --input-file myurilist
RE: Offline apt-get
Postby tuxmando » Wed Dec 12, 2007 1:28 pm
thanks so much, i'll try that
tuxmando
Users browsing this forum: Exabot [Bot] and 1 guest
