OK, here's my puzzle (I trust it has a simple, trivial solution, but I can't find it...):
I have a (a little old, but still wonderful) Sharp M20 currently running Mepis 6.5. It's an extremely lightweight, notepad sized, Transmeta-Efficeon laptop, and it's a life saver, since I can carry it anywhere without any effort... I believe its (on board) wireless might be Prism based, but I didn't look up how to get a positive answer from the system - maybe I should.
It used to run Ubuntu 6.4 and it was great - in particular, WiFi worked right out of the box. When I tried to update to 6.10 or 7.4 WiFi seemed to be lost. On the other hand, with Mepis 6.5 (Ubuntu based) it works again flawlessly....
When LXF came up with the special 7.10 version this month, I jumped on it, but... again, no luck with WiFi (it does recognize the sound system, which Mepis does not - but WiFi is to me more important than sound...). I didn't really install Ubuntu, because I do need the laptop to work, so all this is happening in live mode.
The point is that it realizes there is a card (wlan0). It is able to scan for networks, and finds mine (though it does not post anything about its quality in the graphic scanner). However, trying to give the proper info either to the Gnome or KDE network helpers produces no ability to connect. And even if I give all the right directions manually (iwconfig wlan0 with the proper ESSID and encryption key) dhcpclient does not notice any DHCP offer, and ifconfig with the IP that my router would give to the laptop is accepted, but "network is inaccessible" anyway (and adding the router as the default gateway using route does not change a thing, even if route lists it as, indeed, the default gateway).
I would really like to move to something more current than my Mepis, and I can't figure out why WIFi would be so fussy when a year and a half ago it was so easy... Any ideas? Thanks so much!
