IPv6 is enabled by default in Opensuse as well. I've not come across this problem in Feisty but, intrigued, I did a search on Ubuntu Forums with "The connection to the server was reset while the page was loading" and came up with
this thread among others. Obviously, ignore the suggestion to disable IPv6 but there are some other ideas there. I like the about:config trick - I should think that's worth trying. That idea comes from
this bug report and
this other bug report has another interesting idea - namely to install firestarter to reset the IPtables rules.
I hope there's something of use among that lot. If you decide to download and install firestarter (it's in the Ubuntu repos atm) you'd better hurry. It's been hard-masked prior to being removed entirely from the Gentoo portage tree because - according to a thread I found on Gentoo forums - the firestarter project is dead upstream. If this is true, it's bad news.
Point of information in case you don't know - Ubuntu comes without a GUI frontend to IPtables and firestarter is/was about the most user-friendly of the lot. Perhaps Ubuntu will keep it in the repos or perhaps they'll take the uncompromising Gentoo line. I don't know.
