escputil - Epson printer ink levels
Postby bof » Sat Sep 09, 2006 10:05 am
I have an Epson Stylus C64 printer and it prints ok from Ubuntu.
My problem is that I can't see what the ink levels are. In Windows I had the Status Monitor.
Using Synaptics I installed escputil and when I ran the command line to show ink levels I get:-
tony@tony-laptop:~$ escputil -i|--ink-level
bash: --ink-level: command not found
Obtaining ink levels requires using a raw device.
tony@tony-laptop:~$
Any suggestions as to what I do next?
Local shop built Desktop AMD core duo 4700 dual booting Vista and Ubuntu 7.10
bof
RE: escputil - Epson printer ink levels
Postby Rhakios » Sat Sep 09, 2006 10:21 am
Isn't there a front-end called mtink that you can use for this. I have used it under a variety of Linuxes when I had an Epson printer.
Re: RE: escputil - Epson printer ink levels
Postby bof » Sun Sep 10, 2006 9:30 am
Rhakios wrote:Isn't there a front-end called mtink that you can use for this. I have used it under a variety of Linuxes when I had an Epson printer.
Thanks Rhakios, I followed your suggestion and it "almost" works except I get a message "No access to printer device file. Please make sure mtlink has enough right for accessing the device files"
Any ideas what this lot means?
I followed up on the author's website http://xwtools.automatix.de/english/startE.htm and note that the Epson Stylus C62 is not supported and that the site doesn't seem to have been updated since 2002.
A pity because it did look to be a promising solution.
bof
RE: Re: RE: escputil - Epson printer ink levels
Postby Rhakios » Sun Sep 10, 2006 9:57 am
Actually, you might notice the Status Monitor for Epson inkjet printers was updated May 2006, so it's far from dead. Also, in the README for that file, you will find the C60 listed as known to work, the C64 is probably a variant of this printer.
As for the error message about access rights, this can usually be fixed by running mtink as root, not elegant, but it usually works.
Re: escputil - Epson printer ink levels
Postby nelz » Mon Sep 11, 2006 9:05 am
bof wrote:tony@tony-laptop:~$ escputil -i|--ink-level
This is an invalid command, the #|' is a pipe character, it is taking the output from "escputil -i" and passing to to the command "--ink-level", which doesn't exist.
However, in the man page, the | is used to represent an either/or choice, it means that -i and --ink-level are the short and long options of same thing. Run one of
escputil -i
escputil --ink-level
Re: RE: Re: RE: escputil - Epson printer ink levels
Postby bof » Mon Sep 11, 2006 5:08 pm
Rhakios wrote:As for the error message about access rights, this can usually be fixed by running mtink as root, not elegant, but it usually works.
Thanks for that, sudo mtink did the trick and I even managed to find the C64 listed so it is all working nicely.
Yet another trip to my XP partition has been eliminated. Only one more task to go before I can forget XP.
Thanks Nelz, but I couldn't get escputil under control. Mtink will do me nicely.
I'm thinking of updating my signature to something along the lines of Ringo's "yes, I get by with a little help from my friends"
bof
RE: Re: RE: Re: RE: escputil - Epson printer ink levels
Postby phorneker » Wed Oct 04, 2006 2:36 am
When running escputil to get ink levels, you will need direct access to the printer.
Under ubuntu, you will need to "sudo -i" with your user password to get root access, then type:
escputil -i -r /dev/usb/lp0
or whatever port your Epson printer is connected. Direct printer access is needed to send the ESC/P2 codes needed to get ink levels.
All words found in the Merriam Webster Dictionary including "and", "the", "it", "by", "or" and "not" are registered trademarks of Microsoft Corporation. ;-)
phorneker
RE: Unnatural problem with Epson Stylus c67
Postby nordle » Sun Mar 25, 2007 2:53 pm
I use a different system, and the software may be older.
Install cups (print server / queue manager)
install gimp-print (contains epson drivers)
install libinklevel (library file used by other apps, such as ink, to read levels)
install ink (ink -d /dev/usblp0 will check ink levl on usb printer)
Just some things for you to try if no-one else comes back with anything.
Use the above names and search Yast to see if they are available for suse, might use different setup.
I think, therefore I compile
nordle
Epson Stylus C62
Postby lucyrssll » Mon Aug 18, 2008 12:50 pm
(USER WAS BANNED FOR THIS POST)
lucyrssll
RE: Epson Stylus C62
Postby M-Saunders » Mon Aug 18, 2008 1:10 pm
Thanks for plugging your company here lucyrssll. Oh wait, are you the same lucyrssll who's banned from the Mac Rumors forums, and who has posted the same spam on the OpenSUSE Forum, among other places?
Get off my interwebs.
M
M-Saunders
Postby ajgreeny » Mon Aug 18, 2008 4:38 pm
Try mtink again but make sure you are a member of both lpadmin and lp groups and it should then work as user and not need root.
Xubuntu 16.04 user, and loving it!
ajgreeny
Postby gau_veldt » Sat Oct 11, 2008 7:22 pm
I'm running Ubuntu gutsy with Epson Stylus Color 1400 via USB and getting high failure rate when running
sudo escputil -i -r /dev/usb/lp0
One out of ten times it will work but the remaining attempts wind up reporting "Unknown IEEE 1284.4 error number 66" or "Unknown IEEE 1284.4 error number 69".
I don't get intermittent problems like this when trying to print anything so it's strange.
Does anyone have a way I might fix this problem?
gau_veldt
Epson Stylus Photo 1400
Postby gau_veldt » Mon Jan 25, 2010 12:22 am
gau_veldt
print utility
Postby linux1968 » Mon Jun 21, 2010 2:50 pm
When used in a bash terminal in Kubuntu 10.4 it gives the info without problems.
I have Kubuntu 10.4 and run an Epson R300.
The moment I gave the command in , it shows me :
scputil version 5.2.5, Copyright (C) 2000-2006 Robert Krawitz
Escputil comes with ABSOLUTELY NO WARRANTY; for details type 'escputil -l'
This is free software, and you are welcome to redistribute it
under certain conditions; type 'escputil -l' for details.
Inktkleur Percentage nog aanwezig
Zwart 81
Cyaan 76
Lichtcyaan 77
Magenta 74
Lichtmagenta 71
Geel 68
the only little snag is that it asks for the password before giving the info.
linux1968
Re:escputil - Epson printer ink levels
Postby Rhakios » Wed Jun 23, 2010 4:34 pm
fatima wrote:I think Lexmark scanner software
Unlikely for an Epson printer.
linux1968 are you a member of the lpadmin group? OTOH if scputil is getting information from too low a level for normal users to access you might need to make it suid (or some modification to /etc/sudoers), with the associated security risk. Is typing in your password too much of a chore?
There used to be a nice little gui for epson printers, can't remember its name now.
