Netgear DG834v1 router/ hub update.
Postby chris_debian » Fri Sep 08, 2006 7:45 am
I thought it was about time that I updated the firmware on my router. It says on Netgear's site, that Mozilla Firefox may not work properly with its routers. I notice that several releases of firmware are available.
Firstly, has anyone had problems using Mozilla/ Firefox with Netgear kit (I can log-on fine)
Secondly, does anyone know whether the firmware upgrades need to be done in sequence, or can I just use the latest one?
Many thanks,
Chris.
chris_debian
Re: Netgear DG834v1 router/ hub update.
Postby TheDoctor » Fri Sep 08, 2006 9:03 am
chris_debian wrote:has anyone had problems using Mozilla/ Firefox with Netgear kit
If anyone has, I'm not one of them.
chris_debian wrote:I can log-on fine
Me too :)
TheDoctor
RE: Re: Netgear DG834v1 router/ hub update.
Postby nelz » Fri Sep 08, 2006 10:56 am
I think you'll find the Firefox problem is the IPv6 compatibility thing, not an inability to Firefox to connect to the router's admin page.
Postby chris_debian » Fri Sep 08, 2006 11:38 am
Cheers, Nelz.
chris_debian
Postby rattus » Thu Sep 14, 2006 12:43 pm
I have a v2 model which after upgrade started intermittantly dropping connections. Remedied by (sledgehammer approach?) resetting the router to Factory Defaults and re- entering login details, etc..
rattus
