Sound Volume
Sound Volume
Postby baron » Fri Sep 01, 2006 5:46 pm
Hi
I have Suse 10.1, Unbuntu and Win98se on my box. Using either linux versions
the volume has to be quite high for mp3, cd music or dvd films. If I forget and switch to Win98 without adjusting the sound it is blasting. Indeed its about a quarter on the speaker dial in Win98 and threequarters in Linux for the same volume.
I have a SIS SI7012 card (AC97 codex)
baron
baron
RE: Sound Volume
Postby nordle » Fri Sep 01, 2006 8:47 pm
I've found this too, with all distros I think, if possible make use of any audio 'gain' controls within your linux apps. That way you can leave the hardware level the same for both lin+win.
I think, therefore I compile
nordle
Users browsing this forum: Bing [Bot] and 0 guests
