Software to print cd labels
Postby bof » Mon Aug 28, 2006 8:41 am
I have a stock of Fellowes/Neato cd labels which came with Mediaface software. I failed to get Mediaface to run under Crossover Office so have to go back to XP to print cd labels.
Does anyone know of Linux software that can make use of my Fellowes/Neato labels?
Local shop built Desktop AMD core duo 4700 dual booting Vista and Ubuntu 7.10
bof
RE: Software to print cd labels
Postby Rhakios » Mon Aug 28, 2006 11:41 am
Do they have an Avery equivalent? This page has OpenOfficeorg templates you can use with Worldlabel stock and it gives Avery equivalents, so if your stock has a similar cross reference...
Postby Gordon » Mon Aug 28, 2006 12:36 pm
glabels may be of help:
http://glabels.sourceforge.net/
Gordon
Postby nelz » Mon Aug 28, 2006 3:20 pm
It's probably overkill, but I've used Scribus for this.
Postby wyliecoyoteuk » Mon Aug 28, 2006 8:37 pm
Kde has a program called Kover.
Re: RE: Software to print cd labels
Postby bof » Mon Aug 28, 2006 8:55 pm
nelz wrote:It's probably overkill, but I've used Scribus for this.
Thanks, after researching the other suggestions I,ve gone along with Nelz as I have to put two CDs in the post tomorrow.
Thanks to all :D
bof
