Recommended Mouse/Pen for use with GIMP and Inkscape
Postby tarheel92x » Sat Aug 05, 2006 10:08 pm
I am looking for a recommendation on an inexpensive mouse pen to use with the GIMP and Inkscape. I have found several brands online and it appears WACOM has the most support. I do not want to spend a lot of money (I understand "you get what you pay for") but I am a beginner.
Can someone recommend a model under $50?
tarheel92x
RE: Recommended Mouse/Pen for use with GIMP and Inkscape
Postby emyr42 » Sat Aug 05, 2006 11:53 pm
The larger the surface area the better, as you will be able to have more control over your pen.
OpenSUSE 10.2, WinXPHome
AMD Sempron 2400, 512MB DDR333, Twin 60GB Deathstars
emyr42
Postby Rhakios » Sun Aug 06, 2006 8:14 am
For under $50 you'd be best off looking for a second hand one. It's true that Wacom are the best supported and I have an old Graphire serial tablet working on this computer. But even second hand you'll be lucky to get much for that little money.
found one
Postby tarheel92x » Wed Aug 23, 2006 12:11 pm
I got a WACOM Graphire 4x5 at CompUSA for $99 with a $30 rebate. It works very well with Linux (Inkscape, GIMP) and very much worth the money but being new I didnt want to spend too much.
Thanks for the suggestions.
DB
tarheel92x
