Is windoze vaster a new paradigm in computing?
Is Windoze Vaster a new paradigm in computing?
YES!!,YES!! I loveJohn Honeyball and want his babies.
0
No votes
It's almost as good as hitting myself with a birch twig in the snow
3
27%
Only Debian has the answer
3
27%
Vista? isn't that a double glazing company?
5
45%
Total votes : 11
Postby wyliecoyoteuk » Fri Jun 23, 2006 10:12 pm
Just wanted your take on the increasing hype in the windows-centric media.
edit (maybe I should have put this in the "other OS" forum)
Postby Hello » Tue Jun 27, 2006 4:08 pm
It will be good if it works however it will be pretty much like XP but made far to simple which will resule in about 80 clicks to change a desktop and i dread to think what will need to be done to mess around with things like the bootloader
Hello
Postby Rhakios » Wed Jun 28, 2006 12:01 pm
No, it's lots of old paradigms with the Microsoft logo stuck on the front.
Postby towy71 » Wed Jun 28, 2006 3:43 pm
I thought it was a load of very old paradigms patched with some newer paradigms and then some external modules(viruses or drm) with a Microparp Logo stuck on the front. I'm sure that the Heath-Robison family ought to issue a solicitors note to Billy boy.
Postby GMorgan » Wed Jun 28, 2006 7:32 pm
Whats amazing about Vista is they had a relatively good idea in the relational database indexed file system and then went and dropped it in order to concentrate on a stack of features that are common.
GMorgan
Postby jjmac » Thu Jun 29, 2006 2:52 am
Oh dear ....., or maybe just an old ploy. That is a joke question/statement isn't it. Yep ... i knew that :rolll:
They possibly realise that if they were to run with "good ideas", there is the real danger that their customers will come to expect more of the same, or at least some continuence. That alone could over turn their whole strategy for future releases.
http://counter.li.org
Postby Rhakios » Thu Jun 29, 2006 12:16 pm
If they put anything genuinely knew in there, then yer standard windows user would just moan about not knowing how to use it :twisted:
Postby GMorgan » Thu Jun 29, 2006 3:28 pm
Why not go back to DOS then. I'm still annoyed they took out format. I tell people the best program on Windows is 'format c:' and it doesn't bloody do anything anymore.
Is there any news on the Vista CLI, can you actually do stuff from it now.
GMorgan
Postby wyliecoyoteuk » Thu Jun 29, 2006 8:57 pm
apparently, there is a "powershell" which is (and I qoute a PC pundit ) "almost on a par with the bourne again unix shell"
shock, horror!
Postby GMorgan » Fri Jun 30, 2006 3:52 pm
wyliecoyoteuk wrote:apparently, there is a "powershell" which is (and I qoute a PC pundit ) "almost on a par with the bourne again unix shell"
shock, horror!
What do they mean almost on par. I expect they mean it has fake transparency or something.
GMorgan
Postby wyliecoyoteuk » Fri Jun 30, 2006 7:37 pm
It probably means that it is better than the Dos command shell ( not difficult )
Postby GMorgan » Fri Jun 30, 2006 11:15 pm
Does it mean that if you gave a million monkeys a million years they may eventually type a useful command in the shell.
GMorgan
Postby jjmac » Mon Jul 03, 2006 8:57 am
Either it's a direct rippoff of the shell, but altered to hide that, and so degraded in the process. Or just an empty marking comment. Probably degrees of both. I suppose "Vista' is supposed to suggest something along the lines of "views". With a kind of lose relationship with 'windows' being portals to vistas. hmmmmm, not impressed yet with the marketing team :)
Postby GMorgan » Mon Jul 03, 2006 10:08 am
jjmac wrote:>>
The only view I'm looking forward to is the enevitable MS brand Vista coaster in a few years time
GMorgan
Return to Discussion
