libtool.m4 and ltmain.sh have a version mismatch! Kdevelop
Postby GMorgan » Mon May 01, 2006 9:36 pm
I've just tried compiling an old project on Kdevelop in Gentoo. The problem I'm getting is a complaint along the following lines
checking for correct ltmain.sh version... no
configure: error:
*** [Gentoo] sanity check failed! ***
*** libtool.m4 and ltmain.sh have a version mismatch! ***
*** (libtool.m4 = 1.5.22, ltmain.sh = 1.5a) ***
Please run:
libtoolize --copy --force
if appropriate, please contact the maintainer of this
package (or your distribution) for help.
*** Exited with status: 1 ***
I've emerged libtool which is probably causing the problem butI haven't a clue what to do about ltmain.sh. As far as I can tell there is no ebuild that refers to it (certainly nothing at gentoo.org. Anyone know how to solve this.
I'm also getting a few warnings
/usr/share/aclocal/pth.m4:43: warning: underquoted definition of _AC_PTH_ERROR
run info '(automake)Extending aclocal'
or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
/usr/share/aclocal/pth.m4:55: warning: underquoted definition of _AC_PTH_VERBOSE
/usr/share/aclocal/pth.m4:61: warning: underquoted definition of AC_CHECK_PTH
/usr/share/aclocal/pilot-link.m4:1: warning: underquoted definition of AC_PILOT_LINK_HOOK
/usr/share/aclocal/ao.m4:9: warning: underquoted definition of XIPH_PATH_AO
autoheader
I don't think these are a problem but I thought I'd post them in case they turn out to be important.
GMorgan
RE: libtool.m4 and ltmain.sh have a version mismatch! Kdevel
Postby bluemonki » Tue May 02, 2006 9:18 am
So what happens if you run:
like it asks you to?
A wizard has turned you in to a whale. Is this awesome? (Y/N)
bluemonki
Postby GMorgan » Tue May 02, 2006 9:54 pm
It doesn't give any output. It may have done nothing, or it may have installed rootkits throughout my machine, the complete lack of output leaves me in the dark.
GMorgan
Postby bluemonki » Wed May 03, 2006 12:11 pm
Ok lets stop taking the paranoia pills for a sec and check it out:
http://www.delorie.com/gnu/docs/libtool/libtool_29.html
...right so no rootkits there.
So once you've run the command do you still get the same error?
If you do check this out:
http://66.249.93.104/search?q=cache:NhcODh1KiV4J:www.gentoo.org/news/en/gwn/20041220-newsletter.xml%3Fstyle%3Dprintable+libtool.m4+and+ltmain.sh+have+a+version+mismatch!&hl=en&gl=uk&ct=clnk&cd=1&client=firefox-a
bluemonki
Postby GMorgan » Wed May 03, 2006 10:59 pm
I didn't seriously think there were rootkits I'm just saying for all I know there maybe :wink: .
Thanks for the link. Its a known bug then at least I will be able to get it running.
GMorgan
