Grip options for MP3
Postby Lancer » Sun Nov 20, 2005 2:42 am
I've found that whenever I use grip (gnome-ripper) it creates .ogg files instead of .mp3 files. Nice of Fedora to use the "politically correct" choice here, but ogg files are not good for transporting to a hardware mp3 player. I want mp3 format.
But what I don't know is what the options should be in the Encode >> Encoder tab. I know I have "lame" installed but I don't know the command line extras to get this to work (e.g: the "Encoded command-line" textbox)
Anyone know the correct settings?
Lancer
RE: Grip options for MP3
Postby jdtate101 » Sun Nov 20, 2005 8:16 am
On the Config -> Encode tab there is a enrty box that says "Encode file extension"...change that to mp3.
Ubuntu Edgy & Beryl on:
AMD X2 4800+
4GB Corsair TWINX RAM
2 x Seagate 400GB USB2
Dual Layer DVD-RW
Nvidia 7800GT
2 x Viewsonic VP201b TFT
Iomega Rev Internal
jdtate101
Postby Lancer » Sun Nov 20, 2005 8:44 am
Nope.
It already is set to mp3 and it's still making ogg files. I think that's because the textbox below "Encode File format" contains the string "~/ogg/%A/%d/%n.ogg"
...but even if I change this to ~/ogg/%A/%d/%n.mp3 I do get files ending in mp3 but a file command identifies them as "Ogg data, Vorbis audio" and xmms refuses to play them
This is why I think I need to change the command-line options in the above "Encoder command line" box... I just don't know what that textbox should be changed to.
Lancer
Postby nelz » Sun Nov 20, 2005 11:43 am
Which version o0f Grip? In 3.31, go to the Config tab, encode sub tab and Encoder sub-sub-tab (???). There's a menu gadget where you select your preferred encoder.
Re: RE: Grip options for MP3
Postby Rhakios » Sun Nov 20, 2005 12:34 pm
Lancer wrote:This is why I think I need to change the command-line options in the above "Encoder command line" box... I just don't know what that textbox should be changed to.
That will depend entirely on what encoder you have installed. For instance, I have lame from the pacman archive (as I'm using SuSE). When I pick lame from the Encoder drop down list it automagically changes the command in the Encoder command-line box. Bladeenc is another good mp3 encoder, if you can get it for your system.
(grip version 3.2.0)
RE: Re: RE: Grip options for MP3
Postby Lancer » Thu Nov 24, 2005 5:29 am
The "about" dialogue tells me it's grip version 3.2.0
Config >> Encode >> Encoder looks like...
Encoder: bladeenc (selected)
Encoder executable: /usr/bin/oggenc
Encoder command-line: -o %m -a %a -l %d -t %n -N %t -G %G -d %y -q 4 %w
Encode file extension: mp3
Encode file format: ~/ogg/%A/%d/%n.ogg
...the above results in ogg files being made. Running a man oggenc shows that the executable is unlikely to produce mp3 files as /usr/bin/oggenc is made to "encode audio into the Ogg Vorbis format"
As I have said, as well as bladeenc, I do also have lame but no idea on the proper command options to use in order to configure it to create mp3 files.
Lancer
Postby ladi » Thu Nov 24, 2005 8:36 am
... he's right, as I found out only two nights ago.
You need to tell grip to use lame - or any other program you have that will convert WAV files to MP3. First, select lame in the drop-down list. You will also need to specify the full path to lame in the encoder executable box. Grip will complain if the path is wrong.
My distro (Slackware) does not come with lame by default, so, like me, you may have to download and install it first. To verify the existence and path to lame, type 'which lame' at the command line. Once that is done, you should be a happy man. Don't forget to reduce the bit rate in the encode options, otherwise you end up with the default CD quality MP3s which sound great, but are quite large.
All the best, and let us know how it goes.
ladi
Postby Lancer » Thu Nov 24, 2005 9:14 am
....yes but I did all that before I ever made this thread...
linking to the /usr/bin/lame executable is not enough... because I'm missing the stuff in the other boxes, particularly the "Encoder command-line:" box.
I tried the following...
Encoder: lame (selected)
Encoder executable: /usr/bin/lame
Encoder command-line: --alt-preset standard %w %n
Encode file format: ~/ogg/%A/%d/%n.mp3
...but that is wrong. I think that resulted in files either not being made or perhaps errors (cannot check right now because I am using the player for a big task at the moment). In either case, I have lame but not the options to go with it.
Lancer
Postby nelz » Thu Nov 24, 2005 10:22 am
Doesn't man lame tell you all the available options?
Postby Lancer » Thu Nov 24, 2005 5:49 pm
Yes it does, and that is how I derrived the incorrect Encoder command-line: --alt-preset standard %w %n above.
As with many man pages there are a LOT of options to sort through but what throws me is tryiong to marry them with the syntax grip uses to pass on parameter its. For that there is no simple guide and man grip lists many things which could or could not be useful to lame.
Surely someone out there... uses lame to make mp3 through grip... and can say what the options should be? Especiallly for Encoder command-line: which is the part I'm most certain I have wrong. (when making ogg files that one works out to be -o %m -a %a -l %d -t %n -N %t -G %G -d %y -q 4 %w ) :shock:
I have been a bit rushed to really look into it slowly (teacher at end year writing reports) but will see what I can do over the weekend, posting a core complete analysis of what I'm trying to do. In the meantime, if anyone has it working and cares to say what their options are, much appreciated.
Lancer
Postby Gordon » Thu Nov 24, 2005 6:03 pm
Hi Lancer,
Try these settings using the bladeenc encoder. This is working very well for me at the moment. The homepage for bladeenc can be found at http://bladeenc.mp3.no/
Don't put in the "->" characters I've only used them here as pointers to objects a la c++ :-)
Hope this helps.
Gurgs
Grip->Config->Rip->Ripper->
Rip file format -> ~/MyDocuments/Music/mp3/%A/%d/%n.wav
Grip->Config->Encode->Encoder->
Encoder drop down combo box has -> bladeenc
Encoder executable -> /usr/bin/bladeenc
Encoder command-line -> -%b -QUIT %w %m
Encode file extension -> mp3
Encode file format -> ~/MyDocuments/Music/mp3/%A/%d/%n.%x
Grip->Config->Encode->Options
M3U file format -> ~/MyDocuments/Music/mp3/%A-%d.m3u
Gordon
Postby Lancer » Thu Nov 24, 2005 6:13 pm
Wow! Thanks - I only just edited my post adding the last paragraphs about saying I would look at it more closely... this is going to help tremendously!
I have to rush in to school right now, but thanks and I'll let you know how it works out.
P.S: I can do ogg in BladeEnc already - does it actually do mp3 as well? (I need mp3 so the file can go into a hardware mp3 player)
Lancer
Re: RE: Re: RE: Grip options for MP3
Postby Rhakios » Thu Nov 24, 2005 6:14 pm
Lancer wrote:Surely someone out there... uses lame to make mp3 through grip... and can say what the options should be?
Indeed, but some of us have only just got home from work.
Encoder command line: -h -b %b %w %m
Encode file format: ~/mp3/%A/%d/%n.%x
but of course, if you don't want them in a directory called mp3, then you need to change the first bit to your desired location.
RE: Re: RE: Re: RE: Grip options for MP3
Postby Gordon » Thu Nov 24, 2005 6:26 pm
Hi Lancer,
Yes, bladeenc does do mp3 as well. I didn't know it would also do ogg !
Gurgs
Gordon
Postby davecs » Thu Nov 24, 2005 9:41 pm
I know you are using GNOME, but can you also install KDE, not for the desktop if you prefer GNOME, but for some of its elements. Setting up a Twin-pane Konqueror is, in my opinion, the simplest way to rip CDs. CDs are displayed as a folder containing all the wav tracks, with subfolders showing ogg, mp3 and flac versions. It's just a simple case then of drag and drop.
davecs
