Problem with Synaptic
Postby Alex01UK » Mon Aug 11, 2014 4:30 am
Gives the error message;
E: dpkg was interupted, you must manually run 'dpkg --configure -a' to correct the problem.
E: _cache->open()failed, please report.
So I close Synaptic, open up an Xfce Terminal,
alex@armani:~$ sudo dpkg --configure -a
[sudo] password for alex:
Setting up linux-image-3.13.0-33-lowlatency (3.13.0-33.58) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
initrd.img(/boot/initrd.img-3.13.0-33-lowlatency
) points to /boot/initrd.img-3.13.0-33-lowlatency
(/boot/initrd.img-3.13.0-33-lowlatency) -- doing nothing at /var/lib/dpkg/info/linux-image-3.13.0-33-lowlatency.postinst line 491.
vmlinuz(/boot/vmlinuz-3.13.0-33-lowlatency
) points to /boot/vmlinuz-3.13.0-33-lowlatency
(/boot/vmlinuz-3.13.0-33-lowlatency) -- doing nothing at /var/lib/dpkg/info/linux-image-3.13.0-33-lowlatency.postinst line 491.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-33-lowlatency /boot/vmlinuz-3.13.0-33-lowlatency
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-33-lowlatency /boot/vmlinuz-3.13.0-33-lowlatency
update-initramfs: Generating /boot/initrd.img-3.13.0-33-lowlatency
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-33-lowlatency /boot/vmlinuz-3.13.0-33-lowlatency
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-33-lowlatency /boot/vmlinuz-3.13.0-33-lowlatency
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-3.13.0-33-lowlatency
Found initrd image: /boot/initrd.img-3.13.0-33-lowlatency
Found linux image: /boot/vmlinuz-3.13.0-32-lowlatency
Found initrd image: /boot/initrd.img-3.13.0-32-lowlatency
Found linux image: /boot/vmlinuz-3.13.0-31-lowlatency
Found initrd image: /boot/initrd.img-3.13.0-31-lowlatency
Found linux image: /boot/vmlinuz-3.13.0-29-lowlatency
Found initrd image: /boot/initrd.img-3.13.0-29-lowlatency
Found linux image: /boot/vmlinuz-3.13.0-27-lowlatency
Found initrd image: /boot/initrd.img-3.13.0-27-lowlatency
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
and that is it. It just hangs, as if in an infiinite loop. No error message or anything..
Aha, tia from Alex.
PS I'd like to try The KDE Desktop next. How can I do this without Synaptic?
Alex Armani, IT Consultant \ Digital Musician.
+447 754 595 449 - Www.Armani.PM 8) %)
tB.xx
Www.FaceBook.com/Alex.Armani.01.UK
Alex.Armani@Live.co.UK - E-mail \ MSN
Alex.Armani@RocketMail.com - Yahoo Messenger
Alex.Armani.UK@gmail.com - Google Talk
Alex.Armani@MYspace.com - MYspace IM
Alex.Armani01UK - Skype
@AlexArmani01 - Twitter
AMD QUAD A4 5000, AMD Radeon HD 8330, 64bit Ubuntu Studio 16.10 \ 32bit Mint 17.3 MATE \ Windows 10 Home.
Www Armani.PM <- Live Streaming o24\oo7\366.
''I'm smarter than the average Bear Boo Boo; Let's get some pikkernick baskets!''
tB.xx
Alex01UK
