Evolution and the zombie horde of undead messages
Postby Rojj » Wed Aug 06, 2014 7:17 pm
Hi all,
I currently have 2,700 deleted messages in my wastebasket, and they will not go away. I have highlighted all of them, right-clicked on the folder and the system says they are being expunged, but they come right back again!
I would be grateful for any advice on this.
It may be related that Evolution disconnects and reconnects automatically whenever a message is sent (Yellow panel at top of screen)
Evolution was completely OK with my last long-term distro (Lucid)
Regards,
Roger.
(Debian 7 running on a HP P4 with 2.5G. of RAM)
Roman pottery databases are more interesting than you might think...
Rojj
Postby Dutch_Master » Wed Aug 06, 2014 10:17 pm
Try the following:
rm -R ~/.Trash/
If it fails, try it as root:
rm -R /home/<user>/.Trash
Become your regular user again if you used root (type: exit then enter), then:
mkdir ~/.Trash/
Postby nelz » Wed Aug 06, 2014 11:25 pm
Are you using IMAP or POP3?
Postby Rojj » Thu Aug 07, 2014 11:09 am
Hi Nelz,
I am using IMAP, but some of them have come from a POP3 btopenworld account which was previously linked to my IMAP Gmail account.
I have removed the BT email address from my Google profile, but cannot access the BT one - it is suspended. (Last email sent was from a dial-up connection).
Should I think about installing Thunderbird instead?
Looking forward to your reply,
Roger.
Rojj
Postby nelz » Thu Aug 07, 2014 12:43 pm
Is it a GMail account? Can you delete the mails using the web interface?
Postby Rojj » Thu Aug 07, 2014 3:19 pm
Hi Nelz,
Yes, it is a Gmail account, and I have regularly got rid of the unwanted messages. As of yesterday, there were only 700 messages visible on the webmail interface. All Trash messages had been removed.
Regards,
Roger.
Rojj
(Solved) Evolution and the zombie horde of undead messages
Postby Rojj » Tue Aug 12, 2014 9:46 am
Good Morning All,
Thanks for your help and suggestions.
I'm not sure what I did, but it must have been the right thing!
All of the unwanted messages have now vanished.
Now to update the back-up file to stop them coming back again...
Regards,
Rojj
Rojj
