Finding missing files with a commad or script
Postby GeordieJedi » Sun Jul 20, 2014 10:36 pm
Hi there.
I was wondering if there is an easy and quick way to tell if I am missing a file
in multiple directories and then make a list and output it to a text file.
The situation is I'm running XBMC on my Ras Pi and NAS. Not all of my films (and music) have folder/cover art.
Rather than go through each dir one by one and check. I thought that there must be any easy way to check
this with the terminal command or a bash script.
Something like -
Look at all these dirs (and sub dirs), do they contain the file "folder.jpg"
if not, then name the dir it's missing from and make a list in
a text file for me.
I've taken a quick look on google and I've seen a few that look promising (but they have a bunch of commands
and operators and it quickly begins to look like Klingon).
Any advice or help would be much appreciated.
TIA
GeordieJedi
Postby MartyBartfast » Sun Jul 20, 2014 10:44 pm
basedir=/media/mymusic
for x in `find $basedir -type d` ; do [ -f "$x/folder.jpg" ] || echo "$x" ; done
MartyBartfast
Postby GeordieJedi » Tue Jul 22, 2014 12:34 pm
That worked brilliantly !
Thank you very much MartyBartfast.
You're a star.
GeordieJedi
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 2 guests
