Email Rejected [SOLVED]
Postby DavePritchard » Tue Jul 01, 2014 4:31 pm
Using Kmail, on a clean install of Mageia on a different box,
Emails are received all Ok, but sending mail I get the following.
Failed to transport message: the server did not accept the senders address,
"David Pritchard@localhost.localdomain"
the server responded: #5.1.8 Domain of sender address <David Pritchard@
localhost.localdomain> does not exist.
The account is with Tiscali, I cannot remember seeing anything to do with such settings when setting up Kmail, and there appears to be no way of changing them either in Kmail settings,or the Tiscali web-site. also I do not know what the setting should be.
Any help to resolve this problem will be most welcome.
Dave P..
DavePritchard
Postby nelz » Tue Jul 01, 2014 4:43 pm
It looks like you've given your name where you should have given the email address. That explains the illegal space character and also the bogus domain, if you five only a username the mailer will add the local systems domain name.
Email Rejected
Postby DavePritchard » Tue Jul 01, 2014 5:03 pm
Hi, thanks for the reply,
I did not notice, but my name is automatically put in "from" instead of my Email address, However my name does not appear anywhere in Kmail settings, login = Email address.
Looks like I may need to remove the Email account and recreate it, but not sure if it will do any different, unless a better suggestion is forthcoming.
Dave P..
DavePritchard
