Link to Application
Link to Application
Postby DavePritchard » Wed Jan 29, 2014 10:17 pm
I have installed the XDS Module-2 Compiler into /usr/local/xds/bin
The executable is called xc
Permissions for xc are Owner Read & Write, Group read & Write, Other Can Read. User is root, Group is root.
is executable is ticked.
A Link to Application has been created,
Application Properties = Command xc
Work path /usr/local/xds/bin/
Permissions = Owner read & Write, Group Can read, Others Forbidden, User dave, Group dave.
Clicking on the Icon as user or root results in the following
KDEInit could not launch 'xc'.:
Could not find 'xc' executable. ( BUT ITS THERE !! )
I get the same result with the JAL PIC Compiler.
What am I doing wrong, and how do I get it to run ???
Thanks in advance Dave P..
DavePritchard
Postby lok1950 » Thu Jan 30, 2014 4:22 am
Since you decided to put it in /usr/local/xds/bin it may not be in your path try running it from a terminal opened in it's directory with
./xc &
the & will detach xc from the terminal as a background process so the terminal will be free for other tasks ;)
Enjoy the Choice :)
lok1950
Postby nelz » Thu Jan 30, 2014 8:53 am
You need to give the full path to the program in the link, the work path is not where the program is stored, it is where it defaults to sorting its data files. The Link basically does
Run command
cd to work path
so you need to make sure it can find the command.
Link to Application/PATH
Postby DavePritchard » Thu Jan 30, 2014 6:39 pm
I put it in usr/local/xds/bin because that's where the Install text file said to put it, it then said put usr/local/xds/bin in the PATH,
that's where the problem starts.
From a terminal in usr/local/xds/bin,
Code
./xc &
This works Ok,
So the PATH is missing, in a terminal I used the commands export, then echo, and the required path was on the end of a long list, but it seems it is removed when the terminal is closed, when opened again it is no longer there, I have tried as root and as user.
A recent previous posting advised adding to ~/.profile or bash_profile, I have also seen ~/.bashrc mentioned but using find, neither of these files shows up.
So I am back to square one, I cannot find WHERE or HOW to put usr/local/xds/bin in the PATH.
Confused as ever Dave P..
DavePritchard
Postby nelz » Thu Jan 30, 2014 7:16 pm
~/.bash_profile, as advised in the previous thread. But you should still put the complete path to the command in the Link, because desktops don't always read ~/.bash_profile.
Link to Application
Postby DavePritchard » Thu Jan 30, 2014 9:07 pm
The first problem was, I could not find a /bash_profile file, there was no result using 'find'.
I have now traced it to my home directory, and amended it, so it now has the line.
CODE
PATH=$PATH:$HOME/bin:/usr/local/xds/bin
The Link to Application has Permissions-Application-Command
CODE
usr/local/xds/bin/xc
Clicking on the Icon still presents the following :-
KDEInit could not launch 'usr/local/xds/bin/xc'.:
Could not find 'usr/local/xds/bin/xc' executable.
Dave P..
DavePritchard
Postby johnhudson » Thu Jan 30, 2014 9:47 pm
Is the executable a command line or a graphics program? If it is a command line, you need to open Properties>Application>Advanced Options and check Run in terminal.
Re: Link to Application
Postby nelz » Thu Jan 30, 2014 10:20 pm
DavePritchard wrote:The Link to Application has Permissions-Application-Command
CODE
You're missing the leading / so it is looking for a usr subdirectory of the current directory.
SOLVED Link to Application
Postby DavePritchard » Fri Jan 31, 2014 11:05 am
Thanks for the replies guys.
Forward slash added,
Ticked 'Run in Terminal'
Also ticked 'Do not close when command exits'
And Hey presto it works.
( Just wish these things had a GUI for Linux
which they have for windows ).
Dave P..
DavePritchard
Users browsing this forum: Majestic-12 [Bot] and 0 guests
