OK, now the start of the audio scope...
Postby Bazza » Sat Apr 26, 2014 5:32 pm
CygWin is SSLLOOWW but that has not deterred me from attempting to include it.
The FREQ command works but is totally unusable do to said speed.
The BURST command only works in DSP mode, not DEMO.
SOX has not been included although I might attempt it.
Only tested on an old dual core HP laptop, and a quad core Philips desktop both
running Windows Vista, and a fairly recent version of CygWin.
You will have to set up test and mic inputs yourselves but DEMO mode still works
as normal...
Comments welcome, and tests on other Windows versions would be of great help.
It is uploaded in CygWin guise and is marginally slower on real UNIX like machines
however ALL of the original code is commented out and NOT deleted. All you need
to do is search for CYGWIN and comment out the relevant line(s)
below it and uncomment the single line above it. This changes the hex dumper from
"od" back to the original "hexdump" again...
Also another simple circuit at the end for the DC control pulse under construction.
Other changes too...
Enjoy finding simple solutions to often very difficult problems...
http://wisecracker.host22.com/public/AudioScope.sh
73...
Team AMIGA...
Bazza
Postby Bazza » Sun Jun 29, 2014 9:49 pm
Well chaps lots of changes have happened.
I missed out version 02500 on here and jumped you to 02550
instead.
The unfinished Manual is now generated inside the script and
saved on program exit. The Amplifier and other circuits are now
part of the script. Pulse generators are now created as part of
the calibration proceedures...
I am well into the next upload but want to test it on Raspberry
Pi in DEMO mode first to see the possibility of using it on that
machine...
AudioScope.sh is here:-
https://github.com/wisecracker-bazza/Sc ... azza/Scope
Amplifier photos in here:-
https://github.com/wisecracker-bazza/Sc ... 36c2699286
Enjoy...
73...
Team AMIGA...
Bazza
Re: OK, now the start of the audio scope...
Postby Bazza » Sat Nov 08, 2014 6:05 pm
Hi Guys and gals...
There has been much done to AudioScope.sh and i have missed you lot out.
It is now at version 0.30.20 and you will have to read the file for more information.
There is now a new capture for OSX 10.7.x plus and it creates an AppleScript to use QuickTime Player in quiet mode to snatch an audio snippet.
I am working on a Windows capture using SoundRecorder.exe also in quiet mode for CygWin.
An ALSA version is also in the piepline using arecord as the capture mode.
Soory but I forgot all about you guys...
BTW I am not updating GitHub as it can be a real PITA to access using this MBP.
Here are two pointers:-
And the original host site:-
http://www.unix.com/shell-programming-a ... ipt-7.html
Descriptions of updates are in the URL above thread...
Enjoy...
73...
Team AMIGA...
Bazza
Postby Bazza » Tue Nov 11, 2014 9:12 pm
OK, this new official release 0.30.40 now has a capture for CygWin using SoundRecorder.exe.
It now captures at CD quality in WAVE format and there is a simple converter to convert form
signed 16 bit, stereo, 44100Hz WAVE file to RAW format.
There is a further awk converter to quantise down from 16 bit signed stereo data to 8 bit
unsigned mono data for the 'Scope.
The two hidden commands are OSX107PLUS<CR> for the OSX QuickTime Player capture and
WINSOUND<CR> for the CygWin SoundRecorder.exe capture.
Both are SLOW but work well.
You experiment with them it your own risk as these commands are not visible from the internal
HELP file yet.
Now for ALSA...
Enjoy...
73...
Team AMIGA...
Bazza
Postby Bazza » Sun Dec 07, 2014 8:11 pm
We are now at version 0.30.90.
Lots done here:-
1) Calibrated timebase ranges now in 1,2,5 sequence, commands 1mS, 2mS, 5mS, 10mS, 20mS, 50mS and 100mS.
2) Slowest timebase range also added to complement the Fastest one.
3) Lots of code cleanup but not using latest bash techniques, sticking rigidly to backwards compatibility as far as possible.
4) The second build, DC restorer described in the manual and usage to setup display polarity.
5) The final part of the second build to change the DC restorer to Voltage doubler ready for future use.
6) All captures now not hidden anymore.
7) Other minor things I can't remember at the moment...
8) The AC coupled ONLY vertical amplifier is next...
Everything is now slowly coming together to give a basic AC coupled calibrated AudioScope...
Calibrated DC will be much more difficult using the sound card.
Enjoy...
The script is now 131697 bytes in size...
Bazza...
It can be found here:-
73...
Team AMIGA...
Bazza
Postby Bazza » Mon Dec 29, 2014 6:58 pm
AudioScope.sh version now at 0.30.95...
The vertical amplifier circuit at the end of the script has been modified to suit a comment about using analogue modems' isolating 600 Ohm 1 : 1 transformers. C2 is AC coupled to the transformer now and the emitter resistor is now connectd to ground.
No other changes have been done. The original circuit can still be used without modification so there is no need to alter it.
There is now a SWEEP generator built in and is used for bandwidth and LF roll-off tests.
It goes from 4KHz down to about 85Hz and back, twice. It is a poor squarewave that has a certain amount of sinewave ringing on it, this a function of 8 bit depth and 8000Hz sampling speed but was easy to implement.
Its prime objective is to quickly see how the waveform differentiates at LF and integrates at HF/MF giving a quick assessment of the total amplifier BW...
The command is SWEEP<CR> to run it...
Only three modes can play it back inside the code:-
afplay for OSX 10.7.5 and above.
aplay for Linux machines using ALSA.
/dev/dsp for CygWin and Linux machnes with OSS and PulseAudio.
It does not autorun inside a separate xterm window but is there to create the files to be run on a separate machine.
The manual has been updated to include this and the file is now over 130KB in size... EEK!
Enjoy...
73...
Team AMIGA...
Bazza
Postby Bazza » Mon Feb 02, 2015 10:29 pm
This is the latest release of AudioScope.sh; Version 03120.
Now working on ALTDC a simple home brew board to get DC into the computer via the Mic input...
This is a preliminary text mode drawing of the chopper section only.
This should work from DC to 200Hz to give a total bandwidth from DC to 20KHz through a single Mic input.
It is assumed that the mic BW is from around 300Hz upwards...
The voltage doubler board will be required for this tio work when it is finished.
I am trying to make Arduino redundant as it requires a driver dependency before it can work.
Enjoy...
                                 R3 = 1M
      O/P O-----------------*----/\/\/\----+
                            |            __|__
                           === C1 = 1uF
   LF AC OR    R1 = 1K      |
   DC I/P O----/\/\/\----*--*--+
                         \     o C  Q1 = BC549
                         /      \    b
               R2 = 100K \       \|__o----/\/\/\----O Square wave in from approx 2KHz multivib at TTL level.
                         /       /|      R4 = 22K
                         \     |/_
                         /     o e
    _GND_ O------*-------)--*--*----*---------------O
               __|__     |  |       | +
               /////     |  O     --+--
                         |   /     / \  D1 = 1N4148
                         |  O     '---'
                         |  |       |    R5 = 3K9
 0.7V REF O--------------*--*-------*-----/\/\/\----> +5 to +9V.
73...
Team AMIGA...
Bazza
Postby Bazza » Fri Apr 03, 2015 10:41 am
AudioScope.sh Version 0.31.40.
Due to the numerous choices of Linux installs that are now available I have discovered that some do not have 'xterm' installed by default. This has now become a dependency as Linux Mint 17, 64 bit requires that you install 'xterm' if you need to use it.
Also CygWin did not have semi-automatic calibration of the display polarity.
This is now taken care of using the limitations of 'mintty' used in a default install of CygWin.
More done to the Manual including an ultra-simple detector circuit and usage for the display polarity calibration using a MacBook Pro 13 inch ONLY, (in my case circa August 2012). This may or may not work for other platforms but it is NOT intanded for those.
This is in an Appendix at the end of the Manual.
Very soon this code will be able to be used as a fun, calibrated, AC coupled only tool for anyone to use...
As it stands if you have already built the circuits including the Vertical amp then it is a fun, uncalibrated, usable audio OSCILLOGRAPH. ;o)
Calibrating without the kit is ALWAYS the difficult part.
Stas so far:-
Lines=3451.
Blanklines=28.
CodeLines=1745.
Comments=1678. (Including the Manual.)
Filesize=140746 bytes.
Enjoy...
The shell script is here:-
Bazza...
73...
Team AMIGA...
Bazza
Postby nelz » Fri Apr 03, 2015 7:19 pm
You could check for the presence of xterm in the script
if ! which xterm >/dev/null; then
  echo "You need to install xterm"
  exit 1
  fi
Or use the value of $TERM instead, which should point to the default terminal program.
If $TERM is empty and xterm is not installed, you are screwed.
Postby Bazza » Sun Apr 05, 2015 7:56 am
Hi nelz...
I did something similar long ago, but:-
Last login: Sun Apr  5 08:40:44 on ttys000
AMIGA:barrywalker~> echo "$TERM"
xterm-256color
AMIGA:barrywalker~> xterm-256color
-bash: xterm-256color: command not found
AMIGA:barrywalker~> _
As this is developed on a(n) MBP then this has to take priority...
('xterm' IS in the $PATH on this machine.)
So I have been there and done that.
Great you are looking at it though.
I am struggling now though there are three unfinished bits so far, two are OK and will just take time, but one - EXT-TRIGGER is making my head spin.
I really have no idea how to detect a particular byte value in real time using shell tools streamed via some kind of capture...
LBNL, I am continually updating the script and uploading to the site and it is now at Version 0.31.51...
And a grab of the image:-
http://wisecracker.host22.com/public/03151.jpg
EDIT:
Stats so far:-
# Total Lines=3535.
# Blank Lines=28.
# Code Lines=1799.
# Comments=1708, (including the builtin Manual).
# Filesize=143515 bytes.
LBNL, any other parts that require 'xterm' can be overcome by using a second computer instead. I will make notes in the Manual in due course. Thanks for the pointer though...
Bazza...
73...
Team AMIGA...
Bazza
Postby nelz » Sun Apr 05, 2015 8:58 am
Thinking about it some more, $TERM is used to show the type of terminal, so may be set to xterm even if xterm is not installed, because you have an xterm compatible terminal installed. Using which xterm is the safest way to check the actual xterm program is available.
Postby Bazza » Sun Apr 05, 2015 1:16 pm
nelz wrote:Thinking about it some more, $TERM is used to show the type of terminal, so may be set to xterm even if xterm is not installed, because you have an xterm compatible terminal installed. Using which xterm is the safest way to check the actual xterm program is available.
I had also thought about launching the test signals using a 'for' loop instead if a 'while true' loop in the background without using 'xterm' at all so I might just go in that direction in the future...
On Linux Mint 17, i typed in xterm manually in a terminal and it immediately _asked_ me to enter:-
Prompt> sudo apt-get install xterm
I did and it installed calling any/all dependencies on the way.
So it was not really a problem.
When I had Debian 6.x.x and PCLinuxOS 2009 I did not need to as 'xterm' was in the $PATH.
Anyhow thanks for chipping in.
I am thankful to the mods on here and on www_dot_unix_dot_com to allow this to continue.
Github created some real psoblems for the way I have this machine set up so I have left it dormant FTTB.
73...
Team AMIGA...
Bazza
Postby Bazza » Sat May 09, 2015 6:17 pm
OK, we now have a major upload here.
The Version is now at 0.31.80. It contains a simple method of calibrating the polarity of the waveform for a MacBook Pro 13 inch only.
See the simple circuit very close to the end of the script/manual...
Although I am aware of many aspects of shell scripting that I didn't know when I first started I have stuck rigidly to the original style.
Some new commands added:-
SHELL - Hidden from the built-in HELP section. Assumes xterm exists.
PLAYBACK - Also hidden from the built-in HELP section. Will playback the 1 second captured waveform.
SAVE - A method to manually save the last capture without having AUTOSAVE enabled.
Now the seriously difficult bit. Yeah, this was NOT easy to make simple!
IMPORTANT! Ensure a signal is at the audio input of the MBP.
The TRIG -> EXT mode.
THIS WILL ONLY WORK USING SOX MODE CAPTURE!
I am assuming SOX is the default capture from now on for this part.
Preamble… It is impossible to obtain a binary value, (or binary value pair), from a stream _in_real_time_ using shell scripting.
So I had to do this in PSEUDO-TRIG mode…
How it works. (<CR> == Carriage Return.)
From COMMAND:-
1) Press <CR> to (re)run, HELP or QUIT<CR> TRIG<CR>
2) Set trigger type, <CR> to disable:- EXT<CR>
The window now clears the previous scan WAITING for the remaining setup.
3) Set trigger polarity, +, - or <CR>:- -<CR>
4) Sync point:- U for up 1, D for down 1, <CR> to RETURN:-
 +-----------------------------[COMMAND  WINDOW]------------------------------+
 | COMMAND:- Sync point:- U for up 1, D for down 1, <CR> to RETURN:-          |
 +------------------------------[STATUS WINDOW]-------------------------------+
 | Stopped...        |
 | Synchronisation point set to 87...                                         |
5) After using U or D press…
6) <CR>
 | COMMAND:-        |
 | Synchronisation set to 87, EXTERNAL and waiting...                         |
 | X=Fastest possible, Y=Uncalibrated (m)V/DIV, AC coupled, SOX mode.         |
Now the window hangs until a value, (in this example), 87 is found and the next byte is less than that value, the '-' inputted from 3) above.
It finds those values by capturing a signal at very low resolution, (8000Hz), and if not found keeps recapturing until it has found them.
As soon as they are detected the loop(s) are exited and a new capture at full resolution, (48000Hz), is taken.
Read the code from lines 1311 to 1360 for a more full insight…
Yes it has its limitations and yes there will be a time delay whilst the two values are detected but I could not think of another method.
Find it here:-
File statistics...
# Total Lines=3599.
# Blank Lines=28.
# Code Lines=1841.
# Comments=1730, (including the builtin Manual).
# Filesize=146294 bytes.
Enjoy...
The display in WAITING mode...
73...
Team AMIGA...
Bazza
Postby Bazza » Tue May 19, 2015 6:44 pm
Well it looks like my website is no more so I will attempt to upload the latest UNOFFICAL release of AudioScope.sh here...
Just rename AudioScope.txt to AudioScope.sh and change your permissions.
It must be in your ~/ (home) drawer fro correct operation.
(I am hoping carriage returns are not added to the file.)
This latest version has a Ctrl-C trap for the EXT trigger if it seems to hang. It is tricky to use but works...
I have placed it inline for this one upload just to check but from now on will just ba an attachment.
# Total Lines=3611.
# Blank Lines=28.
# Code Lines=1852.
# Comments=1731, (including the builtin Manual).
# Filesize=146712 bytes.
From now on I will be uploading AudioScope.sh as a text file...
Don't bother to look on github for it anymore as you guys and www.unix.com have been good to pseudo-host
this project without any hassles, (apart from nelz), ;oDD. Yes I have had a few issues with github so therefore
your two sites take priority... ;o)
Thanks admin, moderators and site staff...
Bazza...
AudioScope.txt
AudioScope.sh Version 0.31.93...
(143.27 KiB) Downloaded 81 times
73...
Team AMIGA...
Bazza
Postby Bazza » Sun Jun 28, 2015 12:52 pm
Hi guys...
Well I have entered an area of partial insnity... ;o)
Below is a photo of the 'ALTDC' board for AudioScope.sh...
I have decided to incorporate all three methods for obtaining DC into this MBP via the MIC input.
1) VFO.
2) CHOPPER.
3) COUNTER.
The controller for 1) and 3) is not yet done but that is next on the agenda.
I have started properly coding for the VFO section first but and I have decided just to do an accuracy of 4 bit depth for this. That is 0 - +2V to an accuracy of 0.125V.
This is an official release but no circuit has been _drawn_up_ for the VFO yet.
Version 0.32.20.
The images show:-
1) The ALTDC board which has one more 1M resistor added but not shown
2) The test setup using the very first construction part of this progect as the input board.
Stats...
# Total Lines=3726.
# Blank Lines=29.
# Code Lines=1915.
# Comments=1782, (including the builtin Manual).
# Filesize=151492 bytes.
The black box on the bottom RHS is a 0 to 2.5V variable DC source and will be included in the manual in due course for basic calibration of the ALTDC board.
Also the _very_first_ test piece is being used for the input to set up the calibration...
DC Board.
Test set up...
There are more images but I will upload at a later date as no more than three uploads are allowed.
BTW some feedback would be nice... ;o)
Enjoy...
Bazza...
03220.txt
Rename to AudioScope.sh.
(147.94 KiB) Downloaded 42 times
73...
Team AMIGA...
Bazza
PreviousNext
