What is swap partition?
Postby nordle » Thu Sep 22, 2011 12:43 am
On my PC, the STR uses no more power than if the PC is off but still plugged into the socket. As I don't turn off the PC at the socket, STR was an obvious choice. It works so well and means a boot time of less than 3 seconds.
Uses about 9w
I think, therefore I compile
nordle
