Ipod Touch File Transfer via USB
Postby UncleRay » Sat Jul 31, 2010 5:11 pm
Steps that I learned that transfers files to Ipod Touch via USB cable
SETUP:
Run Ubuntu 10.04
Must transfer one file to Ipod using Itunes and Windows
(hold your nose while doing it)
Install GoodReader app via App Store
TRANSFER PROCESS:
Connect Ipod (duh)
In GoodReader press Wifi Transfer (icon on lower left corner)
Must use web browser connect to port indicated
(mine was 192.168.2.2:8080)
Now use Nautilus option: "Connect to Server"
then select: WebDAV (http)
enter server: 192.168.2.2
enter port: 8080
A new incidence of Nautilus will open
WebDAV will be seen through which files can be transferred to ipod.
Works with many file types: pdf, mp4, mp3, etc.
(Don't know what browser connection must be done first)
Hope this helps.
Never speak in absolutes!
UncleRay
