Can't send Photos via evolution email
Postby TheWizardofOdds » Sat Jul 24, 2010 11:51 am
I'm having trouble sending photos(F spot Manager)with evolution, as attachment.
I'm sending only 8 photos, 17.3 MB. and am receiving error message and that is all.
The ethernet light on my modem flashes constantly when the files are 'sending'.
The files are JPEG. Using latest version of Ubuntu.
Any help much appreciated. This is a major pain and I need to send these today.
* 'DATA command failed, Broken pipe, message not sent'. This is the error message?
Thanks.
TheWizardofOdds
Postby johnhudson » Sat Jul 24, 2010 5:54 pm
How are you send them? My ISP limits attachments to 5Mb though you can send up to five at a time.
Postby TheWizardofOdds » Sun Jul 25, 2010 12:29 am
johnhudson wrote:How are you send them? My ISP limits attachments to 5Mb though you can send up to five at a time.
I initially tried to send all at once, then thought there might be a limit so I tried to send only one photo, still to no avail.
Anyone have any suggestions?
TheWizardofOdds
Postby PCNetSpec » Sun Jul 25, 2010 1:43 am
Googling evolution broken pipe throws up 2 answers
1) Install the exim4 package.
Or
2) Select SMTP in preferences instead of Sendmail when sending e-mails.
see:
http://www.uluga.ubuntuforums.org/showthread.php?p=5183077
and
http://ubuntuforums.org/showthread.php?t=873400
I can't test these as I don't use evolution.
Linux in the UK
The Linux Community Forum
PCNetSpec
Postby TheWizardofOdds » Sun Jul 25, 2010 10:42 am
PCNetSpec wrote:Googling evolution broken pipe throws up 2 answers
Or
see:
and
Thanks for that, I'll give it a shot.
TheWizardofOdds
Postby ajgreeny » Mon Jul 26, 2010 8:49 pm
It may be that the tmp holding time for the files you want to send is too short. I had what sounds like a similar problem with thunderbird, where having chosen the files in f-spot, and made the email message, the "send" would fail, saying the "files in the attachment tmp folder could not be retrieved" or something like that.
It was easily overrcome by adding a new integer key to the gconf-editor for apps->f-spot->export->email as shown below.
delete_timeout_seconds   1800
Use whatever timeout seems needed for you; my 1800 was completely arbitrary, and more than enough, half an hour.
The apps->f-spot->export->email will not exist until you have tried to send photos that way from f-spot, which I assume you have already tried, but by default the timeout key will not exist, though 30 secs is the default timeout not shown.[/img]
Xubuntu 16.04 user, and loving it!
ajgreeny
