Flash card (not)reading
Postby Catinaz » Sat May 08, 2010 12:04 pm
I'm not sure that this is actually hardware question, but please forgive me if I'm in the wrong place.
I have dell vostro 1700 running mint8 live cd installed to usb key. It (usb key) is mounted as cd. Laptop has flash card reader witch takes both (sony) memory stick and SD cards. But system won't read (or shall I put won't recognise) 512Mb Memory Stick PRO (MS) from my sony Cyber-Shot camera. As if it's not there. However, when I put 2Gb SD Ultra2 card, it instantly mounts and shows on desktop. And obviously I am able to brows it. I use later for my Nikon camera.
I am puzzled here. If one can be read, why not other? I would eliminate laptop reader's fault for this very reason. More over, it (MS) works fine under Windows and in camera. It is unlocked if that makes any difference. By "lock" I mean hard switch on card it self to prevent data deletion.
I guess, that FS on both cards should be FAT? The fact, that I am running Live Mint shouldn't cause any problems either?
Any ideas?
Thanks
Cat
P.S. Here is output from dmesg | tail -n30
    [   63.155491]    (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [   63.155495]    (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   63.155499]    (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [   63.155502]    (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [   63.155505]    (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   63.155508]    (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   63.671758] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   63.671762] Bluetooth: BNEP filters: protocol multicast
    [   63.719644] phy0: Selected rate control algorithm 'iwl-3945-rs'
    [   64.317593] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
    [   64.317628] HDA Intel 0000:00:1b.0: setting latency timer to 64
    [   64.339255] Bridge firewalling registered
    [   64.347233] iwl3945 0000:0c:00.0: firmware: requesting iwlwifi-3945-2.ucode
    [   64.377614] usbcore: registered new interface driver snd-usb-audio
    [   64.684998] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input14
    [   64.732362] input: HDA Intel Line In at Ext Left Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
    [   64.732462] input: HDA Intel HP Out at Ext Left Jack as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
    [   64.986664] iwl3945 0000:0c:00.0: loaded firmware version 15.32.2.9
    [   65.073294] Registered led device: iwl-phy0::radio
    [   65.073329] Registered led device: iwl-phy0::assoc
    [   65.073360] Registered led device: iwl-phy0::RX
    [   65.073393] Registered led device: iwl-phy0::TX
    [   65.093083] ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [   65.805214] b44: eth0: Link is up at 100 Mbps, full duplex.
    [   65.805220] b44: eth0: Flow control is off for TX and off for RX.
    [   65.805554] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   75.824041] eth0: no IPv6 routers present
    [   81.781484] lp: driver loaded but no devices found
    [   81.848694] ppdev: user-space parallel port driver
    [  474.096040] CE: hpet increasing min_delta_ns to 15000 nsec
English is not my mother tongue. So, be ready to read bad grammar and reduced vocabulary
Catinaz
