Flashing the firmware on Hard Drives - the linux way
Postby maxeaves » Wed Apr 28, 2010 11:32 am
Hi there,
I have a couple of new harddrives that desperately need a firmware update. They are Western Digital 2TB RE4-GP drives SATA units. Is there a linux tool that I can use to flash the firmware on the drives when it arrives?
Thanks
Max
maxeaves
Postby nordle » Wed Apr 28, 2010 8:42 pm
I tend to use freedos and copy the official dos based exe to it and run it from a booted usb stick.
However, where are you getting the firmware from?
http://wdc.custhelp.com/cgi-bin/wdc.cfg ... 1113493894
http://support.wdc.com/product/download ... 15&lang=en
I think, therefore I compile
nordle
Users browsing this forum: Majestic-12 [Bot] and 1 guest
