LXFDVD135 - How To Install Hugin-2010.0.0
Postby prenticemarie » Tue Jul 27, 2010 11:24 am
As a newbie I have been unable to install Hugin-2010.0.0 from the issue 135 DVD.
I cannot find a "configure" file and ./configure fails.
I have tried "make", "install" etc. to no avail. I would appreciate some assistance, thanks.
prenticemarie
Postby roseway » Tue Jul 27, 2010 11:47 am
Have you checked first to see if it's available from your distro's repository?
Eric
roseway
Postby nelz » Tue Jul 27, 2010 12:02 pm
Hugin uses cmake instead of the traditional autotools. Read INSTALL_cmake from the tarball for the installation instructions.
Whenever you unpack a source tarball, the first thing you should do is read any README and INSTALL files.
Postby prenticemarie » Tue Jul 27, 2010 12:02 pm
Yes, (I am running Ubuntu 9.04) but Synaptic Package Manager does not have version 2010 available.
prenticemarie
Postby prenticemarie » Tue Jul 27, 2010 12:21 pm
Thanks Nelz, I ran the cmake package but it fails at "can't find TIFF package".
This does not appear in Synaptic Package Manager.
prenticemarie
Postby Rhakios » Tue Jul 27, 2010 5:10 pm
prenticemarie wrote:Thanks Nelz, I ran the cmake package but it fails at "can't find TIFF package".
In Lucid it's called libtiff4-dev, so I expect it'll be something very much like that in 9.04.
Postby roseway » Tue Jul 27, 2010 5:40 pm
Does this make it easier?
Eric
roseway
Postby prenticemarie » Tue Jul 27, 2010 8:43 pm
Thanks Guys for your help .... the "cmake" install is now complete after six hours work !
Basically ALL the Ubuntu format "dev" packages had to be installed from the Synaptic Package Manager each time the "cmake" produced an error message, and then re-run the "cmake" to find the next error.
That is DEFINITELY the last time I will install software from LXF, unless there is a "deb" package available.
Thanks again. :P
prenticemarie
Postby nelz » Tue Jul 27, 2010 10:39 pm
That would be a shame as you've done all that work now. Once the -dev packages are installed, compiling from source is quite simple, it's largely a one-off pain.
