Project 3 Chronojohn
Postby kurt » Thu Mar 25, 2010 12:31 pm
I finished up Project three with what appears to be with no problems. I can
issue : /bin/Debug$: ./Chronojohn.exe /home/kpas/Test and back up my files.
06:45 one.129139873560000000
06:59 one.129139883630000000
08:10 one.129139926160000000
06:45 three.129139873640000000
08:10 three.129139926050000000
06:45 two.129139873600000000
08:10 two.129139925870000000
However, when I run: /bin/Debug$ ./Chronojohn.exe list I get the output below.
Unhandled Exception: System.IO.DirectoryNotFoundException: Directory 'list' not found.
at System.IO.Directory.GetFileSystemEntries (System.String path, System.String searchPattern, FileAttributes mask, FileAttributes attrs) [0x00000]
at System.IO.Directory.GetFiles (System.String path, System.String searchPattern) [0x00000]
at System.IO.Directory.GetFiles (System.String path) [0x00000]
at Chronojohn.MainClass.CheckDirectory (System.String directory) [0x00000]
at Chronojohn.MainClass.Main (System.String[] args) [0x00000]
When I run the following command I get nothing printed to the screen.
bin/Debug$ ./Chronojohn.exe list /home/kpas/Test
/bin/Debug$ ./Chronojohn.exe list /home/kpas/Test/
But I get the following output when I run ./Chronojohn
Chronojohn: a backup tool Kurt would have been pround of.
add /some/directory Scan directory and backup changed files
list /some/file List all backup of a given file
restore /some/file <ver> Restore file to specific version
I compared the CD version to what I did in mono but could not find any differences.
Any suggestions would greatly be appreciated.
Postby sciso » Mon Jul 19, 2010 9:52 pm
Hey I'm stuck on Chronojohn myself but if your program is trying 2 backup the non existent /list directory id suggest the line
may be
in your program, that would be the hardest to spot kind of mistake for me anyway.
If not then gl ive got my own hair to replace
Users browsing this forum: Majestic-12 [Bot] and 1 guest
