Cannot execute binary file - Mono program
Postby donoreo » Wed Feb 04, 2009 1:56 pm
I am stuck on the firs project from Paul's coding academy! I am getting the error above. I cannot run the program from a command prompt. It runs fine in MonoDevelop. Permissions are fine. Googling turns up a lot of the same problem with scripts, but not much that helps me. Ideas?
I cannot deny anything that I did not say.
donoreo
RE: Cannot execute binary file - Mono program
Postby M-Saunders » Wed Feb 04, 2009 2:07 pm
Are you trying to run the program with ./progname? You might need to try mono progname.
M
M-Saunders
Postby donoreo » Wed Feb 04, 2009 2:10 pm
Hmmmm yes, it apparently does need that. Paul's tutorial did not mention it, just ./progname . I may just be the first person working on it with all the time I have being unemployed still :( Thanks.
donoreo
Postby Hudzilla » Wed Feb 04, 2009 2:22 pm
Hey!
Yes, you probably need to use "mono ToDoList.exe". I didn't mention it because on Ubuntu ./ToDoList.exe works fine :)
I'll add it.
Paul
Hudzilla
Postby Ram » Wed Feb 04, 2009 3:58 pm
./ works fine on 8.10 but I've found with 8.04 (Dell Mini 9 version) I have to use mono ?.exe
One question if I can highjack this tread, var contents = File.ReadAllText does work for me, gives an error on build. Works if I change it to string contents. This is with 8.04 as above, not had time to try it on 8.10 yet so is this a quirk of 8.04 ?
Postby donoreo » Wed Feb 04, 2009 4:05 pm
I am using Suse 11.1.
donoreo
Postby ollie » Wed Feb 04, 2009 11:37 pm
Is the location of "mono" part of your PATH variable with the correct permissions to access?
See Setting your Path.
Postby Ram » Thu Feb 05, 2009 8:29 am
Cheers for that Ollie, I'll check my PATH on the Mini 9
As for the issue with var, just setup up vbox running 8:10 and no error.
Re: RE: Cannot execute binary file - Mono program
Postby tj-blues » Sun Apr 25, 2010 12:40 am
ollie wrote:Is the location of "mono" part of your PATH variable with the correct permissions to access?
PATH has not much to do with it. Your post confused me for a while so I checked: and yes, mono is installed in /usr/bin directory. But, think, it got to be in PATH because it's sufficient to call "mono program" and not "./mono program".
But still the question is valid - how to make it work without need of issuing "mono" before programname?
cheers
tj-blues
Postby LeoP » Wed Jun 09, 2010 12:28 pm
tj-blues wrote:But still the question is valid - how to make it work without need of issuing "mono" before programname?
Most distros will install binfmt-support with mono, but many will chose not to enable it: Try
sudo update-binfmts --display
and see, if it has an entry like "cli (disabled):". If yes, then
sudo update-binfmts --enable cli
is your friend.
LeoP
Postby Ram » Wed Jun 09, 2010 4:54 pm
cheers
tj, if your path is correct then you run it like ./prog.exe as you would with a sh script - no need to ref mono.
Postby tj-blues » Sat Jun 19, 2010 2:29 am
Ram wrote:tj, if your path is correct then you run it like ./prog.exe as you would with a sh script - no need to ref mono.
As I said before - correct PATH will only point system to /usr/bin directory. It doesn't give any references how the system has to deal with ".exe" file.
I run Suse 11.1 and every time I want to execute C# program I need to type "mono" first.
tj-blues
Postby Ram » Sat Jun 19, 2010 5:10 pm
Hi tj,
You confused me with ./ before mono " it's sufficient to call "mono program" and not "./mono program". "
Anyway have a read of the Registering .exe as non-native binaries (Linux only) section.
Postby tj-blues » Sat Jun 19, 2010 8:49 pm
Ram wrote:Hi tj,
Thanks a lot - this should help. But I think I wont use it because I run other .exe files for ex. with Wine.
cheers
tj-blues
