mp3 jukebox
RE: Jukebox
Postby bigbee » Wed Jun 15, 2005 2:11 pm
idd, running apache from a standard user account, can cause severe security issues...
I suggest running apache with the apache user, and fix permissions for this users instead of running apache with a standard user
bigbee
Re: RE: Jukebox
Postby skecs » Fri Jun 17, 2005 7:59 am
nelz wrote:You would normally set apache to run as user :group apache:apache and keep the files in a directory owned by that user.
Different distros run Apache as different users & groups:
Suse - wwwrun:www
Red Hat - apache:apache
Others - apche:nobody or nobody"nobody
There are others, and you can change this if you want, the joys of Linux. 8)
Regards from
Downunder!
.... _
... (0)>
.. V_/_
Linux Powered!
skecs
