Xandros install
Xandros install
Postby brianread » Mon May 30, 2005 7:28 pm
I am trying to install xandros (the free edition) onto a Pc that I have previously installed Suse 9.3 (and 9.2) sucessfully.
The CD boots fine, and gets to the point where it is "reading CD-ROM data", and it hangs.
I ran it under "custom" and the error message clearly fingers the CD-ROM reading (CMD timeout, etc), however as previous installations have worked fine, I can't see why this one should fail.
I have also tried burning another CD, and it still fails.
I have disabled ACPI in the bios, but it still didn't work.
The CD is on the slave port of the primary IDE bus, and is seen properly by the bios.
Any ideas?
Brian j Read
brianread
RE: Xandros install
Postby Rhakios » Mon May 30, 2005 9:30 pm
Try burning the disc at a slower speed, or trying different (better) media.
RE: Xandros install
Postby brianread » Tue May 31, 2005 5:23 am
Rhakios wrote:Try burning the disc at a slower speed, or trying different (better) media.
I did try a slower burn, and the discs i am using work fine for other distros...
Brian j Read
brianread
RE: Xandros install
Postby Guest » Tue May 31, 2005 4:27 pm
Did you check the MD5 of that disk?
RE: Xandros install
Postby Rhakios » Tue May 31, 2005 6:46 pm
I notice they provide a checksum for the downloaded zip file, so that's okay, but what do you do if it doesn't extract properly? Oh well.
RE: Xandros install
Postby Guest » Wed Jun 01, 2005 1:43 pm
Ok, I re-downloaded the zip file and checked its checksum. Then re-burned a CD, and it still failed the install
I had also tried the previous CD on another system, and it also failed in the same way. the only (obvious) overlap between the 2 systems are that they are both AMd processors (but the not the same AMD - one is a 900Mhz, the other 1.8Ghz (i think)).
RE: Xandros install
Postby brianread » Wed Jun 01, 2005 1:46 pm
Sorry for the last post - I had forgot to login - but it was me though!
Brian j Read
brianread
RE: Xandros install
Postby Rhakios » Wed Jun 01, 2005 7:13 pm
I have only tried the basic paid for version, which was on an AMD system, that was fine. It would be a bit odd if it didn't work on AMD processors.
Edit: I've just had a look on the Xandros forums (eventually, talk about slow) and it seems you're not the only person having this problem with the OCE version, however there are no clear solutions offered in the threads I have read.
Re: RE: Xandros install
Postby nelz » Wed Jun 01, 2005 9:23 pm
Rhakios wrote:I've just had a look on the Xandros forums (eventually, talk about slow).
So that's what Paul did with the old LXF code/server :)
RE: Re: RE: Xandros install
Postby Rhakios » Wed Jun 01, 2005 11:02 pm
I did consider making a similar comment myself, however judging discretion to be the better part, etc. etc..
Re: RE: Re: RE: Xandros install
Postby nelz » Wed Jun 01, 2005 11:56 pm
Rhakios wrote:I did consider making a similar comment myself,
I was surprised that you didn't.
Rhakios wrote:however judging discretion to be the better part, etc. etc..
When did you adopt this new approach to life? ;-)
Postby brianread » Thu Jun 02, 2005 4:54 am
[quote="Rhakios"Edit: I've just had a look on the Xandros forums (eventually, talk about slow) and it seems you're not the only person having this problem with the OCE version, however there are no clear solutions offered in the threads I have read.[/quote]
Yes I've looked there as well - I am going to post a question there, as my situation is slightly different (although similar)
Brian j Read
brianread
Postby Guest » Thu Jun 02, 2005 1:47 pm
Going FROM SuSE 9.3 TO Xandros 3... surely not!
Postby brianread » Thu Jun 02, 2005 3:27 pm
Anonymous wrote:Going FROM SuSE 9.3 TO Xandros 3... surely not!
I am trying distros out mainly for the degree of integration into Windows networks.
Brian j Read
brianread
Postby Rhakios » Thu Jun 02, 2005 6:35 pm
Only on Wednesdays :P
Users browsing this forum: Bing [Bot] and 0 guests
