(solved) Debian Sarge, ifup = no kde or gnome
Postby wiz » Sun May 22, 2005 11:30 am
Debian Sarge 3.1
When I run ifup, the network connection is ok.
Lynx will connect to the internet via eth0 & run without problems.
If I start an X session then kde & gnome startup both hang after a few seconds .
Icewm starts ok.
If I open a browser in icewm and click on a link I am taken to the url.
If I try to type an address, the browser freezes as soon as I touch the keyboard.
If I run ifdown at a command prompt, both kde & gnome start ok.
Can anybody give me a clue where to look to try & fix it?
wiz
Postby Guest » Sun May 22, 2005 11:37 am
Update. I've just discovered I can start kde then run ifup from a terminal window & everything works ok :?
Postby wiz » Sun May 22, 2005 5:28 pm
Fixed !
There was no auto loopback entry in /etc/network/interfaces.
I'm not 100% sure what I'm talking about :oops: but I added it and everything works.
wiz
Users browsing this forum: Exabot [Bot] and 5 guests
