Installing SDL libraries
Postby SiriusHardware » Mon Aug 18, 2014 11:38 pm
After trying out Hatari (the Atari ST emulator) V1.5.0 from my distro's repositories I discovered that Hatari itself is now up to V1.8.0. Windows users get a pre-built binary but the Linux version is made available as source code to be compiled.
I've never attempted to compile from source before but I was sufficiently keen on this to give it a go.
However, I fail at the first step
'./configure'
...Because the process chugs along for a bit, then reports that I don't have the 'SDL libraries' installed. I'm struggling to find out how to go about finding and installing these libraries. I'm assuming (from limited experience with 'c' programming) that these libraries are 'C' source code which will be merged into Hatari as the program is compiled.
apt-cache search for SDL throws up dozens of packages which start with SDL - it's not immediately obvious which (if any) of these is the one I am looking for, or if the methodology for installing these libraries is different altogether.
Distro is Zorin OS 6 (Ubuntu derivative?).
SiriusHardware
Postby lok1950 » Tue Aug 19, 2014 1:10 am
If you are compiling from source you will also need the -dev packages as well as these contain the C++ headers from what their webpage says it only needs the base SDL lib and it's dev version don't forget zlib and zlib-dev if you run in to more problems just post or PM me if you fell embarrassed :wink:
Enjoy the Choice :)
lok1950
Postby SiriusHardware » Tue Aug 19, 2014 7:28 am
So does that mean I just have to apt-get install:
sdllib
sdllib-dev
zlib
zlib-dev
- and then try to compile again. It's as simple as that?
SiriusHardware
Postby lok1950 » Tue Aug 19, 2014 1:47 pm
Yeah that what it looks like if you get any more errors in the configure stage post them here It will be usually just be an other missing -dev lib as they aren't installed by default in most distros.
Enjoy the Choice :)
lok1950
Postby SiriusHardware » Tue Aug 19, 2014 8:01 pm
Not quite so simple so far - maybe I took you too literally, but my Distro has no package 'SDL'or 'SDL-dev' in its repositores. Focusing for the moment on SDL, I went to
http://www.libsdl.org/
Downloaded SDL-2.0.3.tar.gz, extracted the content of that archive to a folder, CDed into that folder and did ./confgure, then when that came to a halt with no apparent problems followed up with MAKE, which also appeared to go smoothly, followed by MAKE INSTALL which failed with a permissions issue until I tried SUDO MAKE INSTALL, which appeared to complete successfully. At this point, I assume rightly or wrongly that I have successfully installed some version of SDL-LIB
However, when I go back to the folder containing the files for Hatari 1.8.0 and go ./configure, it fails after a few lines with
zorin@zorin-desktop:~/Downloads/hatari-1.8.0$ sudo ./configure
-- The C compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Performing Test MUDFLAP_AVAILABLE
-- Performing Test MUDFLAP_AVAILABLE - Failed
-- Looking for include files CMAKE_HAVE_PTHREAD_H
-- Looking for include files CMAKE_HAVE_PTHREAD_H - found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
CMake Error at CMakeLists.txt:87 (message):
  SDL library not found!
This is the relevant section of CMakeLists.txt
# Check for libraries:
find_package(SDL REQUIRED)
if(NOT SDL_FOUND)
   message(FATAL_ERROR "SDL library not found!")
endif(NOT SDL_FOUND)
find_package(Math)
find_package(Readline)
if(READLINE_FOUND)
   set(HAVE_LIBREADLINE 1)
endif(READLINE_FOUND)
find_package(ZLIB)
if(ZLIB_FOUND)
   set(HAVE_LIBZ 1)
   set(HAVE_ZLIB_H 1)
endif(ZLIB_FOUND)
What now?
SiriusHardware
Postby lok1950 » Tue Aug 19, 2014 8:37 pm
It looks like it can not find the headers ie: the -dev part you may have to explicitly add it's path to the configure script.I am not sure but you may be able to add an other source(repo) that has sdl but it may not work as Zorin appears to be a stripped down version of Ubuntu,see if check-install is in your repo it installs complied apps like normal packages so they are easier to manage.
Enjoy the Choice :)
lok1950
Postby SiriusHardware » Tue Aug 19, 2014 8:48 pm
Lok1950, thanks for continuing to help. I'll look into whether I have check-install available.
After digging a bit more I have found the following likely looking packages in Zorin OS 6's repositories
libsdl1.2debian
libsdl1.2-dev
If I attempt to install libsdl1.2debian I'm told it is already installed.
libsdl1.2debian is already the latest version
If I attempt to install libsdl1.2-dev it fails with this output
The following packages have unmet dependencies:
 libsdl1.2-dev : Depends libx11-dev but it is not going to be installed
E: unable to correct problems, you have held broken packages
Not to my knowledge, I haven't. If I try to install libx11-dev manually I get this:
 libx11-dev : Depends: libx11-6 (=2:1.4.99.1-0ubuntu2.1) but 2:1.4.99.1-0ubuntu2.2 is to be installed
E: Unable to correct problems, you have held broken packages
and if I try to install libx11-6 I get this:
libx11-6 is already the newest version
What's going on here? It seems highly likely to me that LIBX11-dev would coexist with the slightly newer 2.2 version of libx11-6 if it would only just give it a try. Is there a way / a switch to get it to bypass this objection, or to install despite the alleged absence of its preferred version of libx11-6?
SiriusHardware
Postby lok1950 » Tue Aug 19, 2014 11:49 pm
Version mismatches can be fatal as the API for the lib may be what changed so the source code you have just may not compile the corruption may have been introduced with the compile/install of sdl from sdl.org.If you haven't done too much customization of your install of Zorin reinstalling it may be an option or getting it's latest which is 8 IIRC .
Enjoy the Choice :)
lok1950
Postby SiriusHardware » Sat Aug 23, 2014 8:00 am
I was really keen to have this working so I took a deep breath and started to resolve the broken dependencies one by one.
The message
Was somewhat misleading, because it appeared that 2.2 was already installed.
I didn't want to un-install libx11-6 2.2 because I was afraid that other software which depended on it would be removed if I did, so to fix that particular problem I did this:-
apt-get install libx11-6=2:1.4.99.1-0ubuntu2.1
-and that downgraded libx11-6 to the particular version that libx11-dev required. I kept going like that until all such broken dependencies were resolved and to my amazement the compiling process eventually made it all the way through, so when I next ran Hatari, it came up with the version number 1.8.0.
Quite pleased with myself, since what I know about Linux could still be written on the palm of my hand.
SiriusHardware
Re: Installing SDL libraries
Postby Petari » Mon Oct 20, 2014 10:54 am
I read this thread because had similar troubles with compiling Hatari in recent Ubuntu Desktop.
Configure stopped with same message about missing SDL . I installed SDL2 and it's dev (header) files, but still got same error.
Tried with compiling SDL - still same.
Solution was to install SDL1.2 - it seems that Hatari wants explicitly that version.
Petari
Postby lok1950 » Mon Oct 20, 2014 4:03 pm
There have been some major changes with SDL2 so I am not surprised that it did not work :wink: along with API changes have a look at the new features that are available.Been following 0AD which have just updated to SDL2 it made supporting MAC Retina displays much easier and simplified the windows build as well but there are still a few bugs that the change uncovered.
Enjoy the Choice :)
my box:Q8200/Asus P5QDLX/8 Gb ram/WD 2Tb 2-500 G HD/GF GT640 2Gb Mint 17.2 Win 7 acer S243HL K222HQL
amd XP1800 on a asusA7N8x/ 789Mb ram/ sda 120 Gb ntfs sdb 80 Gb ext3 (fedora 10) gForce 6800 gt 128 Mb
lok1950
