[ANSWERED] If I ''sudo login'' should I get root?
YES!
1
50%
NO.
1
50%
Don't Know.
0
No votes
Donut Care.
0
No votes
AN Otter. Please specify below.
0
No votes
Total votes : 2
Postby Alex01UK » Wed Jul 09, 2014 11:07 am
Not will I get root, should I get root?
tia aha, from: Alex.xx
AMD QUAD A4 5000, AMD Radeon HD 8330, 64bit Ubuntu Studio 17.04 \ 32bit Mint 18.1 MATE \ Windows 10 Home.
Www Armani.PM <- Live Streaming o24\oo7\366.
''I'm smarter than the average Bear Boo Boo; Let's get some pikkernick baskets!''
tB.xx
Alex01UK
Re: If I ''sudo login'' should I get root?
Postby Alex01UK » Wed Jul 09, 2014 11:43 am
Alex01UK wrote:Not will I get root, should I get root?
'buntu 14.o4 logs in with normal user access priviledges for the user you logged in as. Is this the same for all distributions? Pleese post your results here for me.
ie
CTRL F2
login
sudo login
startx
tB.xx
Alex01UK
Postby nelz » Wed Jul 09, 2014 12:56 pm
Of course you should, if that's what the system administrator has decided you should be able to do. He/she decides what you can and can't do with sudo.
Postby lok1950 » Wed Jul 09, 2014 4:50 pm
Fedora uses policy kit to disable login to a graphical desktop for root and has for about six years now,there is no documented way of doing it.
Enjoy the Choice :)
lok1950
Postby nelz » Wed Jul 09, 2014 7:46 pm
Are you sure they use PolicyKit for that? Fedora uses systemd now. Anyway, it's a good policy, there is no need to run a desktop as root, it is just adding insecurity for no benefit.
Postby lok1950 » Wed Jul 09, 2014 9:14 pm
They may well use systemd but when they first implemented it only policy kit was around IIRC but I have a feeling that it is now integrated into GDM as the no root GUI was a Gnome.org idea part of there enterprise friendly policy,as you stated desktop root is a real security headache in a corporate enviroment.
Enjoy the Choice :)
lok1950
Postby nelz » Wed Jul 09, 2014 10:26 pm
They also disabled Ctrl-Alt-Backspace so you couldn't log in as root in a VC and run startx.
Moved to Discussion, this is not for Help.
Return to Discussion
