Invalid EDID/file system errors
Postby Cagere » Thu Feb 06, 2014 7:16 pm
Hi All.
When I try to boot a previously working Fedora 16 system named "Silver", it fails with the following error message.
"[drm:radeon_vga_detect] *ERROR* VGA1: probed a monitor but no/invalid EDID
An option is provided to hit "Control-d" to continue.
this gives:
[root@Silver ~]# exit
[systemd-fsck[1077]: /dev/mapper/vg-silver-lv_home contains file system with errors.
I can get to a command prompt if this is any use.
An alternative boot option to run "Windows 7" works normally using the same Monitor.
Any suggestions as to how to fix this would be welcome.
Cagere
Postby nelz » Thu Feb 06, 2014 8:38 pm
I don't think the EDID error is relevant, at worst this would stop X loading. More worrying is "/dev/mapper/vg-silver-lv_home contains file system with errors."
Go to the prompt you get, log in as root and run
fsck /dev/mapper/vg-silver-lv_home
to see if the errors can be fixed.
Postby Cagere » Fri Feb 07, 2014 11:10 am
Hi Nelz. Thanks for looking. Unfortunately fsck reports that there is no such file and that this is possibly a non-existant device.
If I go onto the command line and enter the "/" directory and do a "ls" it shows "home" and I can "cd" to it., but if I do a "ls" I get no response. I can see a response from the"boot" directory however.
While at the command line I tried "startx" which showed a shower of error messages before dumping me back at the prompt. One of these I saw as it flashed by said something about "i/o error dev sdb".
Cagere
Postby nelz » Fri Feb 07, 2014 11:33 am
I would expect ls /home to return nothing, the LV isn't mounted so all you have is an empty directory. The missing device tihng is odd, first the system complains it has errors then says it isn't there. What is the output from
lvdisplay
Postby Cagere » Fri Feb 07, 2014 7:21 pm
Hi.
lvdisplay shows three items.
/dev/vg_silver/lv_swap Available 3.94 GB
lv_home " 877.06GB
lv_ root " 50 GB
Each of these has other information if you need it, but they all look very similar.
Cheers
Cagere
Postby nelz » Fri Feb 07, 2014 9:52 pm
So lv_home is there, why can't fsck find it?
fsck /dev/vg_silver/lv_home
should work
Postby Cagere » Sat Feb 08, 2014 9:19 am
Hi Nelz. This last "fsck" did find "home". I was caught out by writing a dash in place of an u/line in my original post. I should have spotted it!
I can't read my own writing. My apologies.
fsck now reports an unattached inode 3015663 and then offered to "connect to /lost+found (y)?". I tried this and it said " count is wrong. it is 2 should be 1.
I accepted the fix offer but it then showed another faulty inode etc-etc.
I seem to remember from another occasion that fsck can fix multiple errors but I can't remember how to invoke it in that mode.
Cagere
Postby nelz » Sat Feb 08, 2014 10:18 am
fsck --help
:P
fsck -y ...
Postby Cagere » Sat Feb 08, 2014 12:18 pm
Many Thanks Nelz. That fixed it.
fsck seemed to have a ton of corrections to make but it did the biz.
Sorry about the previous confusion but the broken machine and this one are in different rooms and I have to transfer messages from one to the other on paper! Perhaps next time I will try photographing the screens.
Cheers cagere
Cagere
Postby Cagere » Mon Feb 10, 2014 11:55 am
HI Nelz. It seems I was a bit premature in saying the problem was fixed. When I turned it off last night it didn't shut down properly and left a similar message about EDID as previously. I went through the routine that fixed it last time, but this time it complained about about problems with"root". I used fsck to fix this and it then said there was problem wit "home" again.
A second run of fsck sees to have fixed that also now and this time the machine seems to have shut down as it should!
There seems to be a serious problem with this drive so I have ordered a replacement and intend to clone it with "G4U" which I have used on a previous occasion. I am leaving the faulty machine switched off and keeping my fingers crossed that it works for the cloning.
Any Thoughts?
Cagere
Postby nelz » Mon Feb 10, 2014 12:42 pm
Are you sure the EDID message was the cause of the failure to shutdown? This seems the sort of non-critical information that would be reported and then the process would continue.
How did you force the shutdown, when it hung? Cutting the power could easily cause the sort of errors fsck is reporting. If the machine appears totally hung, use the MAgic SysRq keys rather then hitting the power button.
Hold down Alt and SysRq while pressing one at a time, in this order
R E I S U B
Postby Cagere » Mon Feb 10, 2014 2:58 pm
Hi Nelz. I don't have any particular reason to think that the EDID message was the actual cause. After seeing this general message I ran fsck with no switches and that is when I got the message about "root" and "home" being faulty. To restart the machine after fixing these problems I used the reset button on the box to restart. On Sunday it did a couple of normal shutdowns using the red logout/shutdown button and subsequently restarted fairly normally although it did seem a bit more sluggish than normal. A new drive should arrive in a couple of days so I will carry on with this old Fedora 12 machine. ( I also have an even older machine with RH8 and Fedora 5 to keep me company). At the moment I am trying to finish a model beam engine which I want to take to the Harrogate exhibition in the Spring so I have plenty to keep me busy.
I will make a note of your suggested shutdown procedeure and stick it on the front panel so that I don't lose it.
Cheersl
Cagere
Postby nelz » Mon Feb 10, 2014 3:01 pm
Pressing the reset button while filesystems are still mounted is a very good way of corrupting them and requiring fsck to get them working again.
