binary install file on debian
Postby guy » Tue Oct 15, 2013 11:41 am
FlightCrew is an ePub book file validator. It is available for 64-bit Linux from here, as a .bin "install file".
I never met one of those before, just rpm and deb. How do I install it on a Debian system, preferably via the desktop software tools so it gets hooked into debian's dependency management and all those good things?
Postby nelz » Tue Oct 15, 2013 12:42 pm
It's an executable, like installing to Windows with an .exe file.
chmod +x FlightCrew-0.7.2-Linux-x86_64-Setup.bin
./FlightCrew-0.7.2-Linux-x86_64-Setup.bin
You don't, the package manager won't know about it because it's an executable, like installing to Windows with an .exe file :(
You could try filing a package request on your distro's bug tracker.
Postby guy » Tue Oct 15, 2013 3:53 pm
nelz wrote:It's an executable, like installing to Windows with an .exe file.
guy@hostname:~/Downloads$ chmod -x FlightCrew-0.7.2-Linux-x86_64-Setup.bin
guy@hostname:~/Downloads$ ./FlightCrew-0.7.2-Linux-x86_64-Setup.bin
bash: ./FlightCrew-0.7.2-Linux-x86_64-Setup.bin: Permission denied
Do I need to sudo or move it to somewhere magic or what?
Postby nelz » Tue Oct 15, 2013 4:07 pm
chmod +x, not chmod -x
You need to add executable permission, not remove it.
As to whether it needs root permissions to run, you'll have to try it. I'd try as a normal user first, in which case it will either install to your home directory or complain about needing root permissions.
Postby roseway » Tue Oct 15, 2013 6:05 pm
I don't know whether this will work, but you might try using checkinstall:
checkinstall FlightCrew-0.7.2-Linux-x86_64-Setup.bin
Checkinstall works by wrapping up the installation files in a .deb or .rpm package, depending on the host system.
Eric
roseway
Postby guy » Tue Oct 15, 2013 6:16 pm
nelz wrote:chmod +x, not chmod -x
D'oh! I knew that! :oops:
Now installed.
Postby guy » Wed Oct 16, 2013 4:18 pm
Installed but baffling. It installed a desktop icon which launches the gui: /home/guy/flightcrew/flightcrew-gui.sh
But clicking the icon or running flightcrew-gui.sh directly has no visible effect, i.e. no gui gets launched that I can see. Tried from bash and got:
guy@hostname:~/flightcrew$ ./flightcrew-gui.sh
/home/guy/flightcrew/./flightcrew-gui: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /home/guy/flightcrew/./flightcrew-gui)
Here is the contents of flightcrew-gui.sh:
#!/bin/sh
# Entry point for FlightCrew-gui on Unix systems.
# Adds the directory the FlightCrew-gui executable is located
# in to the LD_LIBRARY_PATH so the custom Qt libs
# are recognized and loaded.
appname=`basename $0 | sed s,\.sh$,,`
dirname=`dirname $0`
tmp="${dirname#?}"
if [ "${dirname%$tmp}" != "/" ]; then
dirname=$PWD/$dirname
fi
LD_LIBRARY_PATH=$dirname
export LD_LIBRARY_PATH
#if no agruments are passed then call just FlightCrew-gui program; else pass arguments.
if [$* == ""]
then
$dirname/$appname
else
#argument may not be pass correctly without qoutation marks.
$dirname/$appname "$*"
fi
I use Gnome2, so am I right in thinking this is the gates of QT dependency hell? Or is there an easy way?
Postby nelz » Wed Oct 16, 2013 4:22 pm
It's far more serious than that, it wants a different version of glibc from what you have running.
Postby guy » Wed Oct 16, 2013 4:40 pm
Okaay, I think I'll wait for the Wright brothers to fix it. Many thanks, anyway.
