Here's my script:
#!/usr/bin/perl -w
# isbn_convertor - a tool to derive a pre-2007 10-digit ISBN
# number from a post-2007 13-digit ISBN number.
# The first three digits of the ISBN-13 number can be discarded
# but the last digit is a check digit computed from the
# rest of the number and this has to be re-calculated . . .
print "Give us the 13 digits, no spaces or dashes: ";
$isbn13 = <STDIN>;
chomp($isbn13);
# create a 13-element array from the input string:
@isbn13 = split(//, $isbn13);
# calculation of the check digit is explained at
http://en.wikipedia.org/wiki/Internatio ... ook_Number
$multiplier = 10;
for ($i = 3; $i <12; $i++){
$what = $isbn13[$i];
$product = $what * $multiplier;
$sum += $product;
--$multiplier;
$mod = $sum % 11;
$check = 11 - $mod;
if ($check =~ 10){
$check = 'X';
@isbn10 = @isbn13[3..11];
push(@isbn10, $check);
$asin = join("",@isbn10);
print "Your ASIN is $asin\n";
I've tested it with 14 books, I got one anomaly where I mistyped the ISBN for The Suspicions of Mr Whicher and got the ASIN for a different book although other mistypes returned errors from Amazon, I guess the check digit isn't infallible.
