can not boot into Ubuntu now!
Postby Narendra » Thu May 04, 2017 8:32 pm
Hello,
I need help.
I dual boot Ubuntu with windows 10.
updated Windows 10 and restarted the computer to get into Ubuntu but I can't. It says something about logfiles and that i am in emergency mode and to reboot i should press 'systemctl reboot' but it is the same all over.
Please advise.
Narendra
Narendra
Re: can not boot into Ubuntu now!
Postby nelz » Fri May 05, 2017 10:13 pm
Narendra wrote:It says something about logfiles
That's hardly helpful. If you want a useful response, post the actual message.
Postby Narendra » Sat May 06, 2017 9:53 am
Its the Emergency Mode:
Please see the link below.
https://askubuntu.com/questions/646414/ ... ck-problem
I have tried all the options but they do not work.
Please advise.
Thank you, again.
Narendra
Narendra
Postby nelz » Sat May 06, 2017 10:39 am
So is that screenshot the same as you see? Remember, you can see your computer, we cannot, all we know is what you tells us. Try running
journalctl -xb -p err
The -p err should cut down on the output, hopefully making it easier to find the problem.
Postby Narendra » Sat May 06, 2017 3:39 pm
Yes, its the same screenshot I see on the computer.
I have tried your suggestions but they don't work.
I have backed up the ubuntu till the day it crashed and think i will have to reinstall the system. But I dot know what has caused this and can happen again.
Thank you for your help.
Regards.
Narendra
Narendra
Postby nelz » Sun May 07, 2017 9:03 am
What does "don't work" mean? The journalctl command extracts information from the system logs that may help you diagnose the cause of your problem, it will not magically fix anything.
Postby Narendra » Sun May 07, 2017 12:02 pm
Thank you very much for your reply and help.
But i have reinstalled the ubuntu. Could not wait for the repairs.
I do not know what caused the error, it may happen again.
Thank you again.
Narendra
Narendra
