Weird logon failure [SOLVED]
Re: Weird logon failure [SOLVED]
Postby lok1950 » Thu Apr 27, 2017 1:22 am
Glad you got it sorted from that log I suspect that
150.435] (EE) 0: /usr/libexec/Xorg (OsLookupColor+0x139) [0x59ea19]
[   150.436] (EE) 1: /lib64/libpthread.so.0 (__restore_rt+0x0) [0x7ff89f6615bf]
are components of xorg.x11-drv-qxl so that reinstall may have been the door opener the update of both your kernel and nouveau driver just increased your general security(usual kernel updates ) and may be a few bug fixes in the driver a check of the package info with yumex (yumGUI) should give you those indications if you have the right Yumex plug-ins installed :wink: Always wise to look are issues as learning opportunities.
Enjoy the Choice :)
my box:Q8200/Asus P5QDLX/8 Gb ram/WD 2Tb 2-500 G HD/GF GT640 2Gb Mint 17.2 Win 7 acer S243HL K222HQL
amd XP1800 on a asusA7N8x/ 789Mb ram/ sda 120 Gb ntfs sdb 80 Gb ext3 (fedora 10) gForce 6800 gt 128 Mb
lok1950
Postby GregS » Thu Apr 27, 2017 3:55 am
lok1950 wrote:Glad you got it sorted from that log I suspect that
Enjoy the Choice :)
Indeed.
It would be nice to know the precise cause, for any future reference, but just now I'm happy to have resolved it without needing to use the nuclear option...
GregS
Users browsing this forum: Exabot [Bot] and 5 guests
