Jan 2017 - RPi voice control
Postby boodysaspie » Wed Mar 15, 2017 3:05 pm
I'm trying to set up a Pi in my garage to a) play mp3s and b) display my workshop manual in pdf format. I love the idea of voice control - I think moc will do the trick for mp3s, but I'm not settled on a pdf reader.
At the moment I have mupdf, which is lightweight and quick, but I can't figure out how to change pages.
The manual is in one multi-page document. I can't figure out how to issue a terminal command to change pages (next, back, goto <n>).
I've tried to separate each page into its own document, so for example "index" opens the index, but when I then choose "seventeen" I get a second instance of mupdf opening, which is ... wrong.
Ideally I want to close the index page and then open page 17, all in one instance. Failing that, I suppose I could open "index" > close app > open page 17? Is there a polite way to close the app without killing it?
Is there a better pdf app for this purpose, with a command-line interface?
Ta muchly
Re: Jan 2017 - RPi voice control
Postby nelz » Wed Mar 15, 2017 7:06 pm
qpdfview has a D-Bus interface, so you should be able to control it from a script.
Users browsing this forum: Majestic-12 [Bot] and 2 guests
