renaming multiple files
Postby guy » Thu Jan 19, 2017 6:07 pm
Dear Linux geeks, this is the twenty-first century.
I want to rename multiple files in a folder, all with the form [stuff]crop.jpg to [stuff].jpg.
A simple task for bash surely.
[shudder!] regular expressions, switches, a salad of forward- and back-slashes, yecch!
Why can I not do something simple like for example:
But no, I get error messages about the file not being a folder and suchlike.
Please, without becoming a perl expert (I have only one life left), is there an easier way?
"We don't need no frikkin' aliens, we c'n do this ourselves!" — anon.
Re: renaming multiple files
Postby jonni » Fri Jan 20, 2017 11:02 am
The POSIX way to do this is:
do
done
There are many alternatives, including the Linux-specific rename command, or regular expressions. Here we use the % operator to lop "-crop.jpg" off the end of our string. % matches the shortest occurence of whatever you put after it, %% matches the longest, but there is no distinction in this case.
jonni
Postby guy » Sat Jan 21, 2017 10:59 am
Thanks.
The above code is partly working but is not removing the crop.jpg suffix, just appending .jpg to lengthen it to crop.jpg.jpg
Jonni wrote:There are many alternatives, including the Linux-specific rename command, or regular expressions.
Yes. Perl argument hell, regular expression hell, or both to choice. My exact reason for asking for a 21st century way.
Re: renaming multiple files (Solved)
Postby guy » Sat Jan 21, 2017 5:02 pm
All my files had the same prefix, then a number, then the troublesome suffix
So I tried this approach:
for (( i=XX; i<=YY; i++)) ; do
mv "my-prefix"$i"crop.jpg" "my-prefix"$i".jpg"
done;
Worked like a charm.
Would still be nice to know what Jonni's suggestion missed.
Postby nelz » Sat Jan 21, 2017 8:25 pm
You can't use * in a shell command because the shell expands the wildcard before passing the filenames to the command.
It sounds like you want something like krename, which does the job very simply. For a command line alternative, try rename or mmv.
Postby jonni » Mon Jan 23, 2017 10:32 am
As Neil says, perhaps krename or the new batch rename functionality in Gnome Files are the droids you're looking for.
Yes it would, if no one points out my mistakes I'll just keep making 'em. I can see that the hyphen should really be included in the wildcard, but that wouldn't matter unless you had files ending in both hyphened and non-hyphened ways. Also if your files end with, e.g. -Crop.jpg or -crop.jpeg then it'll mess things up. Here's how it behaves on my setup:
Make some files with your filename spec:
$ mkdir test
$ cd test
$ for ((i=1; i<=10; i++)); do touch "thing"$i"-crop".jpg; done
$ ls
thing10-crop.jpg  thing2-crop.jpg  thing4-crop.jpg  thing6-crop.jpg  thing8-crop.jpg
thing1-crop.jpg   thing3-crop.jpg  thing5-crop.jpg  thing7-crop.jpg  thing9-crop.jpg
Yep. Those are some files. Now we run my supposedly shoddy code:
$ for file in *crop.jpg; do mv "${file}" "${file%-crop.jpg}".jpg; done
$ ls
Seems like the desired outcome, no?
jonni
