Loading Linux SUSE 9.1Problem
Postby dreamyoga » Fri Aug 26, 2005 6:04 pm
I want to migrate from XP to Linux SUSE 9.1.
When I try and load from the disc a message indicates that the programme that created the disc is not recognised and I cannot get it from the web.
Any advice welcome?
dreamyoga
RE: Loading Linux SUSE 9.1Problem
Postby towy71 » Fri Aug 26, 2005 8:25 pm
and what exactly do you want us to do? please look here
Postby ollie » Sat Aug 27, 2005 9:23 am
I think you are trying to run a program whilst still in Windows - the SuSE CD/DVD are bootable. You start your computer with the CD/DVD in and press enter when prompted by the BIOS to boot from CD, the SuSE Linux boot menu will then offer to boot from the CD/DVD or the installed HD. Choose the CD/DVD and you can then start the installation. Please read all documentation and screen info, you can wipe your Windows installation if you are planning on dual booting.
