TomB
Posted: Thu Aug 25, 2005 10:18 am Post subject: Distro for an Old Laptop |
I was recently given an old laptop for free. It is running Windows 2000 at the minute.
Specs:
233mhz CPU
64mb RAM
4gb hdd
CD-ROM
Some gfx card that runs at 800x600
I was wondering what are peoples views on what would be a suitable distro to run on it:
I have been looking to run a Fluxbox based distro due to the amount of ram. I have downloaded, Damn Small Linux, Featherlinux, and Julex. I was wondering if I had any other options. I welcome any views people want to give me
Thanks
--TomB |
ollie Moderator
Posted: Thu Aug 25, 2005 10:32 am Post subject: RE: Distro for an Old Laptop |
Grab LXF68 - the mini distro megatest should offer some more options. They reviewed DSL, Feather Linux, INSERT, muLinux, Puppy Linux and ZipSlack. The winner was ... DSL!
Also consider searching for "mini distros" at distrowatch - or just simply browse through the 386 currently on offer  |
RD LXF regular
Joined: Mon Jul 25, 2005 3:53 am Posts: 272 Location: irc.ixl2.net
Posted: Thu Aug 25, 2005 10:34 am Post subject: RE: Distro for an Old Laptop |
take look here for a distro that some had made to run on your model http://tuxmobil.org/mylaptops.html _________________ [url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url] |
towy71 Moderator
Posted: Thu Aug 25, 2005 12:19 pm Post subject: RE: Distro for an Old Laptop |
you could try the excellent Vector Linux which is based on slackware and will run on very low spec machines and could need only 175 MB of hardisk, 16 MB RAM
Dick _________________ still looking for that door into summer |
RD LXF regular
Posted: Thu Aug 25, 2005 4:03 pm Post subject: RE: Distro for an Old Laptop |
towy71, your a genius my wife's laptop is about the same spec as the above and well ive been looking (appently not that hard lol) to get here onto linux as she likes supertux looks like vector could do just the job.
Thanks
BTW them sys requirements right ? 16 MB ram ? wow
towy71 Moderator
Posted: Thu Aug 25, 2005 4:13 pm Post subject: RE: Distro for an Old Laptop |
I know I'm a genius but nelz should take the credit, as he has suggested Vector every time this question is asked  _________________ still looking for that door into summer |
RD LXF regular
Posted: Thu Aug 25, 2005 4:22 pm Post subject: RE: Distro for an Old Laptop |
ok credit to you as well nelz _________________ [url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url] |
nelz Moderator
Posted: Thu Aug 25, 2005 4:36 pm Post subject: RE: Distro for an Old Laptop |
I thought I'd give it a rest this time as it was getting repetitive
I think a lightweight distro is more suited to this than a mini-distro, they are often too limited for general use. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
TomB
Posted: Thu Aug 25, 2005 6:44 pm Post subject: RE: Distro for an Old Laptop |
Thank you for you replies, and I'll start testing suitable ones  |
RD LXF regular
Posted: Fri Aug 26, 2005 4:04 am Post subject: RE: Distro for an Old Laptop |
A bit of advice if your going to use Vector and your laptop cannot boot from cd mount the cd in windows copy the folder called veclinux to C:\ or D:\ make your boot disks and every thing should go fine if you boot from floppys dont try loadlin as its more hassle than its worth, i speant hours trying that loadlin and just would not go, tryed the way i told you and bang every thing went as planned  _________________ [url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url] |
TomB
Posted: Sat Aug 27, 2005 1:24 am Post subject: |
My laptop can boot from CD so it's ok plus I tried VectorLinux in VMware to try it out, and I'm very impressed thank you for your advice |
RD LXF regular
Posted: Sat Aug 27, 2005 2:35 am Post subject: |
no probs mate
my wifes laptop is that old is dont have a cd drive or floppy for that matter lol any way ill get round to installing vector onto it for her _________________ [url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url] |
Joste
Posted: Wed Sep 07, 2005 10:53 pm Post subject: |
Can't miss a chance to plug blueflops, boots from 2 floppies and gives a graphical web browser (links with svga lib) and an irc client, network and dial up. Runs sweet on a 486 with (I think) 4 megs ram (might be  |
Joste
Posted: Wed Sep 07, 2005 10:55 pm Post subject: |
Should be (might be 8 folled by a closed bracket.
That'll teach me to over use parenthesis. |
