KDE
KDE
Postby RD » Sat Aug 20, 2005 2:19 pm
Hi
I remember the very first horrible kde :( today after a lot of umm and arr i updated unbuntu to the new kubuntu thinking well ill have the new kde not much to go by there and all i can say WoW KDE 3.4 is brill i never thought i would see a better KDE than 3.0 though one thing has bugged me im sure some one can tell me how :D that is how do i place the Home and System icons on the desktop ?
Any way other than that i love this version of KDE :D
RD
RE: KDE
Postby Rhakios » Sat Aug 20, 2005 2:27 pm
Not sure what you mean by system icon, but the easiest way to get a Home icon on your desktop is to drag it off the K menu onto the desktop and select Copy. Or, create a desktop shortcut that uses the command
kfmclient openProfile filemanagement
so long as your home directory is the default for that profile it will always open in your home directory.
RE: KDE
Postby nordle » Sat Aug 20, 2005 3:30 pm
re: the system Icon
Unfortunately, in the version Im running, it appears a little bug means it requires a bit more faff than it should.
1. Right click on desktop, select [create new] --> [Link to Location (URL)]
2. Enter URL as system:
3. Click OK
4. Right Click on newly created icon, select [Propertues]
5. Change URL to be system:/
6. Click OK, and it should be fine.
nordle
RE: KDE
Postby mugstar » Sat Aug 20, 2005 3:36 pm
Try a desktop shortcut to kcontrol or kinfocenter, they're the nearest to a windows-type 'System' icon.
mugstar
RE: KDE
Postby RD » Sat Aug 20, 2005 4:42 pm
in kde 3.4 (my distro any way) there is a icon called system where it holds home etc on the menu bar where kmenu is i tryed to create a short cut to the home dir using konqueror but not what i wanted :(
RD
RE: KDE
Postby nordle » Sat Aug 20, 2005 9:21 pm
RD, is that not what I mentioned above?
I think, therefore I compile
nordle
RE: KDE
Postby RD » Sat Aug 20, 2005 10:47 pm
Sorry mate need glasses lol
RD
RE: KDE
Postby linuxgirlie » Sun Aug 21, 2005 9:00 am
Yeah, I'm not to sure about the system icon, (just installed the latest Mandriva with 3.4 - club members only) I like everything being in 'home' but now when I browse up...argh!!
So good idea for windows people...my parents would love it!! But I might have to get use to using it...or go back to 3.3?!?
:D
linuxgirlie
RE: KDE
Postby coolclassic » Sun Aug 21, 2005 5:11 pm
To get kcontrol back
Edit KDE Menu Editor -> add new Item
name it Kcontrol and put in the field "Command" : kcontrol
, choose a nice icon and save !
Done, Kcontrol is back in KDE menu
The world is your playground why don't you play.
coolclassic
Return to Discussion
Users browsing this forum: Majestic-12 [Bot] and 3 guests
