Adobe After Effects Problem - Windows Vista
Postby -Dave- » Thu Jan 22, 2009 11:07 pm
Hey, anyone got the foggiest idea why my screen freezes, and goes dotty like this, everytime I try to load Adobe After Effects?
With thanks Kenco, my coding nightmares are over!
-Dave-
RE: Adobe After Effects Problem - Windows Vista
Postby Dutch_Master » Thu Jan 22, 2009 11:13 pm
Vi$ta doesn't belong on a Linux forum. Try the 'Other OS' section if you really want to ;) Besides, asking twice in the same place only 1 min later isn't considered 'polite' :P (but I'll forgive you for that ;))
Postby -Dave- » Thu Jan 22, 2009 11:18 pm
My bad, I set the post up like 5 hours ago, but had to go afk before pushing Submit. Came back, pushed Submit, had to relog, A blank posting page came up, I hit back in hope that the text is still there, it was, so i pushed submit again. :P
Also.. The forum is called
Help!
The place to post if you need help or advice.
It doesn't say with what :P
"Help, I'm a woman trapped in a man's body...GET ME OUT!!!"
-Dave-
Postby Dutch_Master » Fri Jan 23, 2009 3:58 am
Yeah yeah.... :roll: Be carefull though, or you might end up as 1sf (troll)... (look around here to find that creature... ;))
:mrgreen:
Re: RE: Adobe After Effects Problem - Windows Vista
Postby towy71 » Fri Jan 23, 2009 8:33 am
-Dave- wrote:It doesn't say with what :P
This is the Linux Format Forum and there is a specific "Other OS" forum :roll:
Have you been having too many of your avatar :?:
RE: Re: RE: Adobe After Effects Problem - Windows Vista
Postby M-Saunders » Fri Jan 23, 2009 10:52 am
Moved to Other OS. No worries Dave, but to keep the forums organised we only have Linuxy stuff in Help!
M
M-Saunders
Postby wyliecoyoteuk » Fri Jan 23, 2009 5:02 pm
To answer the OP, maybe it's an after effect ? :mrgreen:
Postby -Dave- » Sat Jan 24, 2009 2:45 am
ba dum dum-tssh
-Dave-
Postby ollie » Sat Jan 24, 2009 11:11 am
I tried to post on this last night (see my post in "This Website").
How much RAM do you have on the system? Do you have a good (less than 12-months old) graphics card? Is Virtual Memory on a separate hard drive, or partition at the very least? Has the same been done with Adobe's Scratch File location? How many "effects" are being loaded by default into the Library?
