Silicon graphics 320 wont go past blue window error message
Postby viktorb » Tue Jan 13, 2009 11:49 pm
Hi
ive just bought a silicon graphics 320 computer
it power up ok but on the monitor it displays a blue window with white text scrolling fast continuously i think i can read the last 2 lines which may say something like time error
I dont have a keybourd plugged in ( ps/2 ) would that be a problem to start up. USB mouse plugged in and works.
It just will not go past this blue window error message,
Its a intel pentium 3, running Windows 2000 pro, i think,
with 3 hard drives, Cd, and floppy.
would re-installing win 2000 fix this?????
thanks
Viktor
viktorb
RE: Silicon graphics 320 wont go past blue window error mess
Postby pwbrum61 » Wed Jan 14, 2009 9:25 am
It may be that windows doesn't like the lack of keyboard. If you don't have a specific need to run windows on the system, try booting off a Live CD/DVD and see what happens - preferably with keyboard and mouse attached.
Another possibility is that the BIOS battery is dead and needs replacing (this would cause a message about the system clock needing resetting I believe).
Where's the Kaboom? There's supposed to be an Earth-shattering kaboom! :D
pwbrum61
Postby ollie » Wed Jan 14, 2009 9:26 am
Definitely plug a keyboard in and do a cold boot. Is the white text POST testing error messages or is it the boot sequence messages from Windows?
Re: RE: Silicon graphics 320 wont go past blue window error
Postby viktorb » Thu Jan 15, 2009 12:06 am
pwbrum61 wrote:It may be that windows doesn't like the lack of keyboard. If you don't have a specific need to run windows on the system, try booting off a Live CD/DVD and see what happens - preferably with keyboard and mouse attached.
thanks for your reply.
Ill look for a keyboard and mouse, first, hope its as simple as that.
and also look into the battery issue,
SGI replied also, and needed serial no. so i am waiting for their response
I think the 320 is running Windows 2000 pro sp1,
as it came with a CD and other visualizing cds,
Give me some time to get the keyboard and mouse (ps/2 i think i need)
and when all goes well i will reply with the result.
regards
Viktor
from South Australia
viktorb
Postby viktorb » Thu Jan 15, 2009 12:34 am
ollie wrote:Definitely plug a keyboard in and do a cold boot. Is the white text POST testing error messages or is it the boot sequence messages from Windows?
HI
can i plug in any keyboard and mouse, with a USB plug,
the 320 has 2 usb plugs in the back, but the instruction book says, use a PS/2 keyboard and the mouse plugs into the side of the keyboard.
booting
im not sure what post testing or boot sequence is, but.......
when the 320 starts,
all green lights flash for a while, except one HD in the Internal lower case
where it holds the System drive (lower) and Option drive, Slave (above)
this HD that sits just above the lower system HD, the green light on the front keeps flashing, intermittently.
All other lights are off,
regarding what i see on the monitor.
I press the 320 on button,
all green light flash for a while,
and on the screen the first and only image i see is
a large blue window in the middle of the screen with white text scrolling fast, the text is in English, not dos stuff , and the only text i can pick up is the lower two lines, which, are testing the clock, it looks like its about 20 items that it is checking, one line for each item, and on the right its passed or not passed,
and these same 20 lines just keep repeating,
this blue window with the scrolling text is in the middle of my screen
on a background of a light blue grey texture, (like an IRIX)
So like an indy or indigo2, Irix GUI,
soft and delicate to look at, unlike windows.
Hope this makes more sense,
many thanks for your time and help
Viktor
South Australia
ps i like Marvin
viktorb
RE: Re: RE: Silicon graphics 320 wont go past blue window er
Postby ollie » Thu Jan 15, 2009 2:16 am
The best source of information for your SGI320 is Silicon Graphics 320â„¢ Visual Workstation Owner's Guide.
HTH
Postby Steogede » Wed Feb 11, 2009 5:22 pm
viktorb wrote:I press the 320 on button,
That doesn't sound like any sort of Windows error, could be the POST (Power On Self Test), it seems very verbose for a POST but I've never used an SGI machine. If the text is scrolling to fast to read, your best option is to try to stop it with either the 'pause/break' or 'scroll lock' keys (presumably). Failing that, you may be able to photograph it.
You seem to have mentioned a lot about flashing LEDs, most PC BIOS use beep codes to indicate various errors - it appears from the manual ollie posted that SGI use flashing LEDs instead, so that might be worth looking at SGI 320 Troublshooting
Steogede
