Debian 3.1 desktop problem - please help novice.
Postby Hinders » Mon Aug 15, 2005 12:02 pm
I wonder if you can help me. I am a complete novice in Linux.
I brought my first Linux Format magazine last week and yesterday I finally decided to take the plunge and try and install Debian 3.1 from the magazine DVD (LXF70).
I created a partition on my Dell laptop and installed Debian on the new partition. I installed Debian and everything seemed to be okay. However I then noticed I had a problem.
My desktop is set at 800x600. I looked through the menu's to find how to change the resolution of the desktop but when I found the correct place 800x600 was the highest resolution available to me. I know that my laptop is capable of a lot higher than this but it wasn't available to select in Linux, why is this?
How can I make the resoloution of my Debian 3.1 desktop higher that 800x600?
Do I need to redo the whole installtion process again? If so do I need to boot from the DVD or is there a program I can run from within Debian?
I hope you can help me.
Please could you keep the information & instructions simple as I may not understand them as I haven't really used Linux yet.
I appreciate any help or information given.
Thanks!
Neil
Hinders
Postby cypress » Sat Nov 26, 2005 4:26 am
all that you have to do is go to a command prompt and run
dpkg-reconfigure xserver-xfree86
Good Luck!
cypress
