Disabling CD-ROM drive eject button
Nobber
PostPosted: Mon Aug 15, 2005 12:48 pm    Post subject: Disabling CD-ROM drive eject button Reply with quote
When a CD is mounted, the eject button on the CD-ROM drive is disabled (usually). Which is nice (or not, according to personal taste). So...
Q: How can I disable the eject button on my CD-ROM drive when there's NO disc in the drive?
There must be a simple software solution to this problem!
PostPosted: Mon Aug 15, 2005 1:08 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Duct tape Very Happy
Nobber
PostPosted: Mon Aug 15, 2005 1:48 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Around my son's fingers, or across the CD-ROM drive?
PostPosted: Mon Aug 15, 2005 3:23 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Found the following on the web...
http://www.informit.com/articles/article.asp?p=24152&seqNum=4&rl=1 wrote:
Disable CD-ROM drive eject buttons
Some newer CD-ROM drives, especially those from big-name manufacturers, ship with a jumper- or switch-operated feature to allow the user to completely disable the frontal eject button while leaving software eject intact. Even in the absence of such an option, you may be able to disable the button manually with a little tinkering, though doing so will likely void your warranty. Once the button has been disconnected or disabled, a CD can be inserted only after the user has logged into Linux and issued the eject command.
I also saw mention of a program called setcd that seems to be able to do what you want - if you're running Debian you can get a package from here, I've seen mentions of an RPM but haven't located it.
Nobber
PostPosted: Mon Aug 15, 2005 3:54 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
setcd looks like just the ticket - thanks! (I'm running Slackware, but I can just download the source code from a Debian repository. Open source is handy like that.)
Nobber
PostPosted: Mon Aug 15, 2005 4:32 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Or not...
Looks as if setcd allows you to enable the eject button even when a CD is mounted - but I want the exact opposite!
Sad
PostPosted: Mon Aug 15, 2005 4:49 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Rats...
Looks like it's back to the Duct Tape, then Sad
Of course, you could always leave a mounted CD in the drive...
PostPosted: Mon Aug 15, 2005 5:11 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Try cdctl. the options include
-oA --lockdoor=A lock or unlock the eject button
or you could stick to duct taping his fingers put of harm's way Smile
Nobber
PostPosted: Mon Aug 15, 2005 5:17 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
Aha! [cautious optimism]Looks more promising...[/cautious optimism]
PostPosted: Mon Aug 15, 2005 5:29 pm    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
cdctl or the duct tape? Very Happy
Nobber
PostPosted: Thu Aug 18, 2005 9:22 am    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
And...it works!
(cdctl --lockdoor, that is.)
cadmium3
PostPosted: Mon Aug 29, 2005 7:32 am    Post subject: RE: Disabling CD-ROM drive eject button Reply with quote
thanks for the help, trolled to get this fix.....kinda new to the forum...
Have you every tried Alien Package Converter (http://www.kitenet.net/programs/alien/) to change deb's to rpm's? works pretty slick like!!
Thanks for the cd fix too!!
Wink Wink
Ted Brown
Inland NW Gaming & Systems, LLC
