Kernal Panic - unable to find suspended data...
Postby Cjam » Thu Aug 11, 2005 8:02 pm
Help please, I had a fully working dual boot machine with Mandrake and XP - all was going swimingly, until some bright spark suggested that XP operates better if individual bits have their own partition (such as virtual memory, my documents etc).
I dutifully split my drive up, sadly while XP now works better than before (hurray), I get the following error when I try to boot into Linux.
resuming from /dev/hda7
resuming from device hda7
Kernal Panic: Resume machine: Unable to find suspended - data signature ( - misspelled
What I guess has happened is the partitions have moved around a bit, and what was the Linux bit (swap file etc) is now not. The bootloader still operates (LiLo), although I cannot get into any Linux stuff unless I boot from a Live CD.
Any ideas anyone? How can I get back to where I was before?
Help Please
Cheers
Jools
Cjam
RE: Kernal Panic - unable to find suspended data...
Postby A-Wing » Thu Aug 11, 2005 9:45 pm
Well resuming tends to suggest it is trying to recover from a hybernate state.
Try the 'noresume' kernel option
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby jjmac » Fri Aug 12, 2005 10:08 am
Does that mean XP has written something to the bios conserning power management or something. Why would the partitions move around !?
What does the table actually look like [ cfdisk -Pt /dev/hda ]. did you use XPs' fdisk to create the new partitions ?.
Sounds wierd. (Just curious).
http://counter.li.org
