ASCII characters
ASCII characters
Postby alloydog » Thu Aug 11, 2005 2:30 pm
Is it possible to get the full ASCII character set, as with Windows where you type Alt+the ASCII character code, such as Alt+0188 for the 1/4 symbol?
I have a laptop with a US keyboard, but I live in Finland and often find I need a few more letters...
alloydog
RE: ASCII characters
Postby fingers99 » Thu Aug 11, 2005 7:09 pm
It's possible, but not by the alt+ method. Use (in Kde) KCharSelect (usually somewhere under utilities). There are facilities like xmodmap & xkeycaps which will allow you to modify your keyboard (for example, you're bound to have surplus windows keys).
fingers99
Postby alloydog » Thu Aug 11, 2005 7:14 pm
I was thinking about 'relabelling' the keyboard and loading the Finnish key map, there are still characters I frequencty use, such as fractions, the plus/minus sign and so on.
I suppose once I have relabelled the keyboard, I could add an 'alt-gr' character to a few more keys, but I was wondering if there was an easier way...
alloydog
Postby jjmac » Fri Aug 12, 2005 10:02 am
man ascii will give you characters up to 127, and man iso_8859_1, iso_8859_15, and man iso_8859_7 will return character from 160 upto 255. Not exactly a keyboard short cut, but something.
http://counter.li.org
Postby davecs » Sat Aug 13, 2005 7:49 pm
Did you know that in Linux it is not too hard to re-allocate the symbols you get when you press the Right-alt key (optionally plus Shift) with another character? Also the symbols you get using Compose (normally the "Windoze menu key" plus two or more keys in succession.
I did a "How-To" on another site:
Keyboards, Numlock and Special Characters
Hope that's of some help.
davecs
