Installing PHP ...
Installing PHP ...
Postby rossc0 » Wed Aug 10, 2005 4:00 pm
I've got some new space on a vm with debian sarge. I've configured php5.0.4 to be the same as work and apt-got all my libraries required.
But I get this when configuring:
Generating files
updating cache ./config.cache
creating ./config.status
creating php5.spec
creating main/build-defs.h
creating scripts/phpize
creating scripts/php-config
creating sapi/cli/php.1
creating main/php_config.h
main/php_config.h is unchanged
creating main/internal_functions.c
creating main/internal_functions_cli.c
| License:                                                           |
| This software is subject to the PHP License, available in this     |
| distribution in the file LICENSE.  By continuing this installation |
| process, you are bound by the terms of this license agreement.     |
| If you do not agree with the terms of this license, you must abort |
| the installation process at this point.                            |
Thank you for using PHP.
However, I dont have a make file! What do I need to install to make it ??
I have installed: automake1.9, cmake, and make - but still no file!
Any ideas ?
rossc0
RE: Installing PHP ...
Postby fingers99 » Wed Aug 10, 2005 5:19 pm
I really don't understand why you're doing it this way. Why not just apt-get install php?
fingers99
Postby rossc0 » Thu Aug 11, 2005 8:54 am
going for php5 - which isnt in the repository
rossc0
Postby fingers99 » Thu Aug 11, 2005 5:04 pm
Get it from unstable: it's been there for quite a while.
fingers99
