is it possible?
is it possible?
Postby jetli68 » Wed Aug 10, 2005 10:34 am
i have knoppix 3.8 installed on hardrive but all so got knoppix 4 dvd is it possible to upgrade from 3 to 4 with out having to format?.is there some thing i could type in the terminal window ?
tia
also could someone help me with this prob?
i tried debian on the cover disk it install ok but when i reboot i get a black screen saying
login i type my name then press enter then type password and press enter
and thats it no desktop loads or anything i picked desktop when installing have i done some thing wrong?
cheers all
p.s be nice linux newbie
jetli68
RE: is it possible?
Postby nelz » Wed Aug 10, 2005 10:57 am
What happens if you type
startx
after logging in?
It seems like X isn't starting, either because it isn't set to start or because it is not configured correctly. Trying to start it manually should tell which, and give some pointers to potential causes if it is a configuration problem.
RE: is it possible?
Postby jetli68 » Wed Aug 10, 2005 10:59 am
cheers will try that and see how i go
jetli68
Postby M0PHP » Wed Aug 10, 2005 11:41 am
To have X start on bootup, you will need to edit /etc/inittab as root, and change the initdefault line to 5, instead of 3 :D
M0PHP
Postby nelz » Wed Aug 10, 2005 1:08 pm
Debian uses runlevel 2 for everything, whether you are starting X or not. The 3/5 in inittab is mainly used in the RPM distros, Slackware uses 3/4 IIRC and Gentoo uses 3 for everything.
I suspect the problem here is that X is failing to start.
Postby youlikeicecream » Wed Aug 10, 2005 1:56 pm
Hi MOPHP, I have been wondering for ages, where this business is :
"To have X start on bootup, you will need to edit /etc/inittab as root, and change the initdefault line to 5, instead of 3 Very Happy"
Also, I know you can login as yourself or root and type 'startx' to login, But how do you run KDM or GDM from the console ?
Mike :)
youlikeicecream
Postby Rhakios » Wed Aug 10, 2005 7:56 pm
You wouldn't really want to run kdm or gdm after logging in would you. One or the other should start automagically (depending on which you have opted for) if 5 is your default run level.
But if you have already logged in you don't need a log in manager, and you can't run one before you start X because they require X to be run.
Or are you trying to do something else?
Postby nelz » Wed Aug 10, 2005 8:19 pm
It's Debian, the default runlevel is 2. I still think it is probably a configuration issue, what does startx do?
Postby Ram » Thu Aug 11, 2005 3:56 pm
Its loads the GUI.
Postby nelz » Thu Aug 11, 2005 4:06 pm
Are you having the same problem as jetli68? If so, and startx starts X, you must not have gdm in your default runlevel. To fix this type, as root
ln -s ../init.d/gdm /etc/rc2.d/S99gdm
