Wireless phone for VoIP (i.e. Skype)
Postby wawrzek » Mon Sep 08, 2008 10:34 pm
I looking for a way to use VoIP but through cordless phone. If I'm right I can
a) buy USB phone
b) use normal phone with some kind of connection (SIP)
I tired a) but it didn't work (see http://larryn.blogspot.com/2008/09/cordless-usb-phone-not-working-with.html)
So I'm thinking about b). Could you suggested any working hardware?
Could you be also so kind and ensure me how it works. Can I choose which line (standard or Skype/Ekiga/...) I'm using? Do I need any special software?
Of course you don't need to describe everything here links are fine. To many results in google can be a problem if you are not sure what you are looking for...
wawrzek
Postby mm tylor » Wed Aug 21, 2013 4:25 pm
In my point of view, you should go to visit your mother because there you can get the answer of your question and also can get a phone for VoIP services.
mm tylor
