gedit
PostPosted: Sun Aug 07, 2005 6:47 pm    Post subject: gedit Reply with quote
The current LXF slams gedit as neither a plain text editor nor a script editor.
On another thread pau1ie doesn't want to be told how to use gedit. Fair enough, he's way past that point.
I stll think it's a handy text editor for people who don't want to know what a scripting language is, even if LXF can't imagine judging it by any other criterion. All the basic tools I need are where I expect them to be, and they just work. Not rocket science I know, but how many text editors can you really say that for. The LXF reviewer didn't say why they found it humdrum for this purpose - I wonder why they did?
Maybe I need to play with NEdit a little, to see what I am missing?
Cheers,
Guy
The eternal noob
jlarue
PostPosted: Sun Aug 07, 2005 7:26 pm    Post subject: RE: gedit Reply with quote
Gedit is, in my humble opinion, the best application I've ever used. It exemplifies the essence of the Gnome philosophy: simple, direct, easy-to-use, with just the things you need, a clear menu structure, and extensibility without compromising any of the above.
So there!
M0PHP
PostPosted: Sun Aug 07, 2005 9:21 pm    Post subject: Reply with quote
Yep, Gedit rocks... who cares about crappy Emacs and vi? Not me ... nano/pico and gedit all the way!! Cool
davecs
PostPosted: Sun Aug 07, 2005 9:50 pm    Post subject: Reply with quote
Personally I cannot get used to Vi or Emacs. I think the continuing arguments over Vi and Emacs represents the worst aspect of Open Source Snobbery. As long as Linux users continue this pointless argument, yer average punter will be put off trying Linux.
Gedit is a tabbed editor, and even though I am not a Gnome user, I think it does what it's meant to do and does it well.
Kwrite is good, and if you need something a bit more complex, Kate is easy to learn (as is anything where the standard cut+paste services work).
As for text-only mode, when I have to, I use nano. I would prefer it if there was a text editor for console use which could make use of console mouse services and used all the regular keys for cut/copy/paste/save etc, actually I must confess that, from my old M$ DOS days, I actually like M$ Edit, and something simple like that would be nice for when I get trapped in a console.
Gordon
PostPosted: Sun Aug 07, 2005 9:56 pm    Post subject: Reply with quote
Personally I'm a big user of the jed editor. It can be used from the console or in an xterm. It also comes with xjed, which can be run as an x application. xjed also responds to mouse clicks to activate the menus.
You can get it from
http://www.jedsoft.org/jed/
In order to compile jed you'll also need the slang library. This is included with SUSE 9.3
Gordon
View user's profile Send private message Yahoo Messenger
jer1ch0
PostPosted: Sun Aug 07, 2005 11:43 pm    Post subject: Reply with quote
Glad someone posted this. I use gedit alot and find it perfect for my needs. My 2 cents.
Marrea
PostPosted: Mon Aug 08, 2005 12:34 pm    Post subject: Re: RE: gedit Reply with quote
So there!
And I wholeheartedly agree with you. I wasn't even aware of gedit before using Ubuntu, where it seems to be the default text editor. I had always struggled with vi in SuSE. All I ever want to do is make slight amendments to configuration files and I think gedit is so quick and easy for doing that. I doubt I'll ever bother with quirky old vi again !!
Erin
PostPosted: Mon Aug 08, 2005 6:21 pm    Post subject: RE: Re: RE: gedit Reply with quote
Gedit replaced with Leafpad. Gedit is too fat for my PC. Leafpad does mostly what Gedit does with notepad lightness plus a few extras.
Erin
alloydog
PostPosted: Thu Aug 11, 2005 10:00 am    Post subject: RE: Re: RE: gedit Reply with quote
In my Windows' entrenched world of technical writing, I torment users of abominations such as Adept Epic, with taunts of "real men use Notepad"
On my Linux PCs, I find GEdit actually better that Notepad, as it is more flexible (bigger files, tabbed windows & so on) and is great for editting systems files when you don't want to use a fully fledged word processor.
I use Vi is I ever get stuck at the command line, or if I just can't be @rsed to open another applicatyion and browse to the file concerned, as it is easier to just type [b]vi /path/to/file/filename. However, Vi is still a pig to use...
PostPosted: Thu Aug 11, 2005 10:04 am    Post subject: RE: Re: RE: gedit Reply with quote
alloydog
I know its a little thing but could you please alter your sig to read "Imagination is more important than knowledge."
TIA
Dick
PostPosted: Thu Aug 11, 2005 7:44 pm    Post subject: Re: RE: Re: RE: gedit Reply with quote
towy71 wrote:
alloydog
TIA
Dick
I believe I have commented on this before: every time I have seen this quote used in a sig, there is some sort of error in it. I now believe it is designed to annoy people who have enough knowledge (actually, mere attention to detail) to spot the error: a way of suggesting they lack imagination perhaps.
alloydog
PostPosted: Thu Aug 11, 2005 8:19 pm    Post subject: RE: Re: RE: Re: RE: gedit Reply with quote
Actually it was a copy/paste error, however, I have tried several times to change the sig, but it just won't have it!
PostPosted: Sat Aug 13, 2005 10:07 pm    Post subject: RE: Re: RE: Re: RE: gedit Reply with quote
<back from bonnie Scotland />
Sooo...
What about that in-depth Life and Times of gedit with down-and-dirty how to write extensions, for the next available LXF?
Evil Nick to allocate the writing of same to the last staffer left in the room after he's finished reading this.
Nobody left? Oh well, I'm glad to find my opinion is not alone, anyway.
Cheers,
Guy
The eternal noob
